Welding exhaust on C5?
Old Apr 27, 2009 | 02:43 PM
coyote 70's Avatar
coyote 70
Default Welding exhaust on C5?
The driver side muffler is hanging low, can be positioned by hand. I reached under the car and the exhaust pipe was not welded to the flange behind the CAT, can this be welded on the car after disconnecting the negative battery cable? I am concerned about the control modules being damaged.
Dave
Old Apr 27, 2009 | 03:23 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I'm assuming you're concerned with an electric welder. Yes you can weld it on the car. Done it before with no issues. When you weld with electricity, you are creating your own independent circuit between your ground clamp and electrode.
Old Apr 27, 2009 | 06:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Disconnect the NEG battery cable, and connect the welding grounding lead as close to the welding area as possible. You will be fine.
BC
Old Apr 29, 2009 | 08:23 PM
coyote 70's Avatar
coyote 70
Apparemtly the fleange weld failed on the h pipe, going to the shop to see if it can be welded or needs to be replaced.
Old Apr 29, 2009 | 10:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any one with a common MIG welder can repair it. It aluminum coated mild steel. Buff off the aluminum coating with a power wire brush and weld it.
BC
Old Apr 30, 2009 | 12:38 PM
coyote 70's Avatar
coyote 70
Just returned from the muffler shop, the factory weld did not penetrate the flange at all. They ran a bead and it is solid now, but it has me starting to think if I should replace the exhaust sytem.
Dave
Old Apr 30, 2009 | 01:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dave
Dave
If you replace the over the axle mufflers,,,,,do it for personal sound quality and appearance. NOT for performance. Find a muffler system on someone elses C5 that you like for looks and sound quality and COPY IT. REMEMBER,,,,,,,if they have a cam and heads and you dont, your car will sound different.
A decient muffler system is the ZO6 C5 ZO6 Ti mufflers. You cant beat them for sound, quality, weight and performance. They can be had used on the forum for $350-$400:
Aftermarket mufflers give a C5 anywhere from 3-10 HP but,,,,if you have a free flowing exhaust and add more HP mods later,,,,they will sure help!
BC
Old Apr 30, 2009 | 03:41 PM
TrplBlk01's Avatar
TrplBlk01
I had my exhaust was welded on. Good to go
To Welding exhaust on C5?
