Need alittle help.
Old Apr 27, 2009 | 10:47 PM
hamptonwskb's Avatar
hamptonwskb
Default Need alittle help.
I am going to do a ls-6 intake swap on my 99frc in a couple of weeks and I need to know what all I need to switch my intakes out. Do I need new gaskets if so which? Also do I need some kind of colant pipe if so where do I get it at. thanks for the advice.
Old Apr 28, 2009 | 11:06 PM
hamptonwskb
Bump
Anyone?
Old Apr 29, 2009 | 10:34 AM
timemender's Avatar
timemender
Maybe the link below will help some. Article shows LS1 to LS6 PCV conversion.
http://www.ls1howto.com/index.php?article=18
Old Apr 29, 2009 | 10:43 AM
Gideon's_Test's Avatar
Gideon's_Test
Just did the same thing on my '99FRC a couple of weeks ago..
Gene Cully has the coolant pipes:
12602544 – Coolant Pipe
12602540 – Coolant Plug Qty 2
http://forums.corvetteforum.com/1569566656-post1.html
Gaskets are re-usable, as long as they're not torn or otherwise damaged...Also, consider sealing the knock sensor while you're in there.. I took the opportunity to replace my OPS as well as a TB bypass...
Old Apr 29, 2009 | 10:44 AM
Gideon's_Test
Also, here is the LS1HowTo article specifically for LS1 to LS6 IM swaps:
http://www.ls1howto.com/index.php?article=5
Old Apr 29, 2009 | 11:49 AM
MattB's Avatar
MattB
You can actually trim the bottom of the LS6 intake to clear the LS1 coolant tube. So, you end up not needing anything. If your lucky, you may be able to find the thread here that has some pics of how to do it.
Old Apr 29, 2009 | 10:48 PM
hamptonwskb
thanks for the advice. Ill check those pages out.
To Need alittle help.
