what is a good Cam>>>>>
Feb 2, 2002 | 10:12 PM
i have a 98 coupe want to put cam in but not change the heads<< what is a good cam to put in ??? it has a 6 speed...
Feb 2, 2002 | 10:18 PM
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: what is a good Cam>>>>> (maticam)
What other mods do you have now or what will you be adding in the future??
Feb 2, 2002 | 10:54 PM
Re: what is a good Cam>>>>> (CHRIS NJ C5)
have X-pipe, LS6 intake, vortex air system may add more after the cam not sure yet>>>
Feb 3, 2002 | 12:07 AM
Cruise-In V Veteran
Re: what is a good Cam>>>>> (Buckmaster)
you will not be able to go too aggressive without doing the heads and or a computer reprogram. I would call Comp cams or Crane and see what they recommend. :)
Feb 3, 2002 | 12:37 AM
Thunder 220/220 114 baby!! :yesnod:
Feb 3, 2002 | 01:36 AM
What do you want the cam to do for you? That is the question you should be asking. Once that is understood, then the proper combo can be found.
Feb 3, 2002 | 06:16 AM
St. Jude Donor '05
Re: what is a good Cam>>>>> (OliverM5)
OliverM5 has a great set up!
Feb 3, 2002 | 03:16 PM
St. Jude Donor '05
Re: what is a good Cam>>>>> (wallstAL)
MTI B1 & T1 Cam are very popular, some like the GM Hot cam!
Feb 4, 2002 | 02:23 AM
Navigator
I agree with New Jersey Chris.
Call Comp Cams and go with their recommendation. They've ground a cam or two.
Feb 4, 2002 | 02:30 AM
thanks all for input>>>>
