electrical issue with headlights
Old Apr 28, 2009 | 01:13 PM
vinnyxgunz's Avatar
vinnyxgunz
Default electrical issue with headlights
high beams work... they both go up and down and they both light up no problem
low beams both go up... they both don't go down... and only the driver's side lights up
i use to have HIDs, i'm back to stock... fuse issue?
thanks for the help in advance
Old Apr 28, 2009 | 05:21 PM
Bluefire's Avatar
Bluefire
You'll need to add the "in-line resistor" to fool the car into thinking you have OEM light bulbs. I bel;eive that DJ Motorsports sells them.
Old Apr 28, 2009 | 06:00 PM
lucky131969's Avatar
lucky131969
OP says he has stock bulbs...
Old Apr 28, 2009 | 07:13 PM
Bluefire's Avatar
Bluefire
Opps! Thanks I read it too fast. :o
Old Apr 28, 2009 | 08:25 PM
vinnyxgunz's Avatar
vinnyxgunz
so now what? ha
Old Apr 29, 2009 | 02:07 AM
Bluefire's Avatar
Bluefire
When you installed your HID's did you also install a relay harness to get the HID's to work correctly? Is the current wiring completely stock now? Do you have power at the headlight socket? If you don't, I have the schematics in the service manual. Depending on what you find I can give you other places to check to diagnose it.
Old Apr 29, 2009 | 09:28 AM
vinnyxgunz's Avatar
vinnyxgunz
when i had my HIDs i just took the stock harness from the stock bulb, put that in the ballast, and ran the HIDs. everything worked for a while. all of a sudden one day they wouldn't go down and the passenger's side wouldn't light up. i removed everything and used the stock harness with the stock bulbs. same thing. passenger's side won't light up and both headlights won't go down - i have to put the lights in high beam mode and then they go down. i never changed my fuses - i'm thinking it's probably a bad fuse?
Old Apr 29, 2009 | 10:00 AM
lucky131969
The fuse for the right low beam is #8 in the underhood electrical center. After reviewing the schematic, the highbeams have no affect on the headlight doors opening or closing. Only the position of the headlight switch raises or lowers the doors, not the low or high itself. I would try turning on the twilight mode to see if the light sensor will open and close the doors automatically.
To electrical issue with headlights
