Help Seat and Steering Wheel Stopped Working
Old Apr 28, 2009 | 09:17 PM
nfratto's Avatar
nfratto
Default Help Seat and Steering Wheel Stopped Working
Today steering wheel adjustment stopped working and the electric seat adjustment does not work. The Passenger Seat does work. Any ideas? Did not check the fuse yet if you could let me know the fuse position to check it would be appreciated.
Old Apr 28, 2009 | 09:27 PM
byronhunter's Avatar
byronhunter
Might be some help, Check Fuse #4.
Old Apr 28, 2009 | 10:00 PM
nfratto's Avatar
nfratto
Ok I checked the Fuse and it is ok swapped it with the passenger side seat fuse. The only function on the memory switch that works is the left and right side view mirrors adjust. The steering wheel does not move and the seat and air bladders for the sport seat are dead. I did check to make sure they are plugged in and tight they are. When I press the memory switch is it supposed to blink when it is doing its thing cannot not remember the correct function.
To Help Seat and Steering Wheel Stopped Working
