C5 Computer codes
Old May 2, 2009 | 05:04 PM
87convpaul's Avatar
87convpaul
Default C5 Computer codes
I get intermittent P1416, air check valve. I have never got into the fix as it goes away as quickly as it comes. This week i got 5 codes at
A0 LDCM & 3 codes at A1 RDCD which is something to do with door control modules. Everything seems OK with both doors. Is this something I should worry about on my 01 roadster?
Paul
Mukilteo, WA
Old May 2, 2009 | 06:00 PM
lucky131969's Avatar
lucky131969
Paul
Mukilteo, WA
Hard to make a suggestion if you do not post the specific codes..
Old May 5, 2009 | 01:59 AM
87convpaul's Avatar
87convpaul
Lucky,
OK, All the A0 LDCM & A1 RDCM codes were "H". On Sunday when I checked my P1416 problem it was also "H". This has been intermittent for some time now. I have read in the Forum about spraying carb cleaner into the air pump rubber hose and blowing it into the pass side check valve. The next time I get P1416, I'll do it.
Paul
Mukilteo, WA
Old May 5, 2009 | 09:32 AM
LDB C5's Avatar
LDB C5
You might invest in a service manual
Old May 5, 2009 | 09:48 AM
lucky131969
Lucky,
Paul
Mukilteo, WA
Rock on..
To C5 Computer codes
