Split Trans - Two Fluids?
Old May 4, 2009 | 06:17 PM
Tim01Coupe's Avatar
Tim01Coupe
Default Split Trans - Two Fluids?
I cannot find anything anywhere on this, forgive me if it's a repeat, or I am completly missing something, BUT, unlike conventional transmissions, our C5 trans is "split" to distribute weight, with the torque converter at the motor, and the rest (case) directly in front of the differential, seperated by the tourque tube, so, are there two seperate trans fluids to check and maintain??
Old May 4, 2009 | 07:02 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
no...
I am not sure how you check the fluid level in the auto, but in the manual there is just a plug on the side that the fluid should be up to.
Old May 4, 2009 | 07:32 PM
95BLKVette's Avatar
95BLKVette
Same for the automatic and the torque converter is mounted to the front of the tranny
Old May 4, 2009 | 08:14 PM
byronhunter's Avatar
byronhunter
Old May 4, 2009 | 08:19 PM
clif's Avatar
clif
St. Jude Donor '09-'10
The torque converter in an A4 is in the rear with the tranny' not up front.
In a manual, the clutch IS at the flywheel.
Old May 4, 2009 | 08:26 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Old May 4, 2009 | 08:27 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
To Split Trans - Two Fluids?
