ABS Sensor Wire Harness
Old May 6, 2009 | 10:09 AM
speedyhawk101's Avatar
speedyhawk101
Default ABS Sensor Wire Harness
OK guys I was a dumb *** and now I need to fix my boo boo.
I forgot to plug in the wire for the wheel sensor and the wire was drug for a good distance.
Where can I get a new wire assembly for the front passenger wheel speed sensor?
Old May 6, 2009 | 10:28 AM
ronwc's Avatar
ronwc
Whay not just splice the two wires together -
Old May 6, 2009 | 10:33 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call Gene Culley (www.gmpartshouse.com) for the best price. I ordered 4 from my LOCAL STEALERSHIP and they charged me friggen $25.00 each for the harness connectors!!!
Gene will have the BEST price. I have the part numbers at home and will post them later tonight when I get home.
There complete pig tails and will need to be spliced in. Recommend soldering and heat shrink covering the soldered connections.
OR
If your talking about the front wheel "jumper harness" that was damaged, Gene will have that also at the best price. I dont have the part number for thhe jumper harness but Gene will.
BC
Old May 6, 2009 | 11:08 AM
87SAM's Avatar
87SAM
Yes, Gene has the best price at $18.84. GM PN 15306302, AC Delco PN PT1357, Napa PN ECHEC11. Many auto part stores can carry them but expect to pay $25 to $30.
Old May 6, 2009 | 08:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is the front wheel jumper harness:
This is the repair splice that is used to replace a damaged female connectors:
Which one did you destroy
BC
Old May 7, 2009 | 12:21 PM
speedyhawk101
OR
BC
Thanks Bill
Thank you too
BC
Can't see the pics at work. I'll try and check them out tonight at the house.
Thanks again for all of your help.
Old May 7, 2009 | 07:12 PM
mickey_7106's Avatar
mickey_7106
can i just buy the complete wire? i would solder it if i knew how
Old May 7, 2009 | 08:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The front wheel speed sensor JUMPER HARNESS is available thru GM. If,,,you damage a chassie wiring harness connector or a component connector or one goes bad,,,,,,you will have to solder that connector pig tail on!
BC
Old May 20, 2009 | 12:04 AM
speedyhawk101
Marking for later
To ABS Sensor Wire Harness
