I was looking at mast motorsports web site, they make an ls7 with 650 hp .
and an lsx with 700 hp.
will this fit into the c5?
If so how much would labor cost for the install for the ls7 . Its a 427/650 hp
They are LS based engines....bolt right in, just make sure you get the correct reluctor for your computer ( 24X ).
They built my 440 (LS7). Plus they run the engine in for you and do power pulls w/ a sheet for you showing your flywheel power curve.
