Vacuum testing
Old May 7, 2009 | 10:44 AM
jonwymore's Avatar
jonwymore
Default Vacuum testing
I have a rough idle issue that is still nagging at me and i want to check the vacuum system and see if that is causing the problem as i have already put new plugs,wires, several bottles of fuel injector cleaner, air filter, replaced the fuel filter and checked the fuel pressure and all are fine. Im at a loss as to how to check the vacuum system or the layout of the vacuum lines in the C5, any one got any advice or pics/layouts of how to check this system would be most appreciated thx.
Old May 7, 2009 | 10:51 AM
LoneStarFRC's Avatar
LoneStarFRC
You can use the vacuum port on the right-hand side of the intake manifold where your pcv hose hooks up.
