Auto Entry
Old May 7, 2009 | 04:12 PM
FXHICKEY's Avatar
FXHICKEY
Navigator
Default Auto Entry
I have a 1999 C5 and my key fob stopped working. I followed the owners mannual to reprogram as well as changing the battery in the fob. When I follow the instruction the Readout does not tell me that the Fob has been learned, The fob initially works but as soon as I remove the key the fob will no operate anything. Any advise?
Old May 7, 2009 | 04:39 PM
huttler's Avatar
huttler
try doing it the old fashioned way, don't mess with the DIC. Put the key in, turn it to on and the hold the lock & unlock button for approximately 8 seconds. I don't know if this will fix it but worth a try
Old May 7, 2009 | 05:38 PM
glkfam's Avatar
glkfam
Sounds like the fob is not communicating with the car, if the DIC does not acknowledge that you are trying to program a key fob. Something is up. Maybe like Huttler says try it the old-fashion way. Holding the lock and unlock button together for about 5 to 10 seconds until you hear the car beep. But if you still have a problem there is a thread on here about some guys resoldering a few points on the circuit board in their fobs and getting them to operate again.
Old May 7, 2009 | 05:40 PM
lucky131969's Avatar
lucky131969
The key need not be in the ignition.
Old May 8, 2009 | 09:20 AM
dancin1's Avatar
dancin1
Default Key fob...
I had the same problem with the fob on my '98 coupe, did the same things with replacing the battery, did the relearn thing and continously did the lock/unlock at the same time and finally removed the fob from my key ring till I could buy a new one. Then thanks to this forum, found a post from C599, Senior member, on 12-18-2008; 10:37 pm outlining his procedure for either soldering or super glueing the battery points back together inside the fob. Since I'm an old F!@#T my hands are a bit too shakey to try to solder and since I was at the point of throwing the original unit away and buying a new one, I tried the fix with super glue. It worked just fine and have been using it for 2-3 months now with no problem, even the passive feature works just fine. I have no idea how to link the post here, but, here's the information...Title:Legendary problem solved...by C599, CF Senior member, at 12:18-2008, 1037pm. 2 pages of good information (I printed it out...remember I'm old) with pictures and very good info on how to do it. Try it.
Old May 8, 2009 | 11:52 AM
bucwheat's Avatar
bucwheat
I program mine standing next to the car.
Old May 8, 2009 | 02:25 PM
huttler's Avatar
huttler
If the key doesn't need to be in the ignition couldn't someone program their FOB to any vette of similar year? This concerns me
Old May 8, 2009 | 03:11 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
x2 button push is a reprogram
To Auto Entry
