Help! Harmonic Balancer Bolt Issues
Old May 7, 2009 | 08:29 PM
vette98c5's Avatar
vette98c5
Default Help! Harmonic Balancer Bolt Issues
This winter I decided to freshen up my 150K LS1 by putting on a new timing chain and oil pump. I put it back together with a new harmonic balancer bolt and tightend the crap out of it with a 3 foot long cheater bar. It still came lose after 3,000 miles and the balancer slid loose all the way to the rack and pinion. Any hints on how to do it right this time would help. Thanks
Old May 7, 2009 | 08:32 PM
clemsondave's Avatar
clemsondave
Did you reuse the same bolt?
Old May 7, 2009 | 08:58 PM
lucky131969's Avatar
lucky131969
Old May 7, 2009 | 11:49 PM
geezel's Avatar
geezel
A new bolt properly torqued and you shouldn't have a problem. I don't know if I could have achieved 240 ft lbs on my ARP bolt with just a 3' cheater, the torque wrench I used was about 5' long. When you've got the pulley nearly seated, make sure and use the old bolt to pull it all the way on and torque to 240 ft lbs. Then remove the old bolt and install the new bolt.
Old May 8, 2009 | 12:21 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Way too much missing info here to tell you where or what EXACTLY went wrong but here is what I have seen happen WRONG in the past:
Old OEM Bolt was REUSED!
New Bolt was used but NOT TORQUED properly.
A new bolt was used but old damper was used and the interference fit between the damper snout and damper was incorrect!!
New bolt used, new damper used but bolt was NOT torqued properly.
Everything was done properly BUT,,,,the damper rotated on the crank snout causing the bolt to come loose.
Those are the scenarios that I can think of at midnight!!!
I have approx 60 HP over stock and I decided to PIN the crank to the Damper to eliminate this very issue.
BC
LUCKY,,,,,, NO COMMENT!
Old May 8, 2009 | 12:31 AM
lucky131969
BC
I'm just listening on this thread.....don't mind me....
Old May 8, 2009 | 02:22 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
BC
All good info here. For the OP, did you measure the TQ on the bolt or did you just tighten it with the sally bar? Did you reuse the original bolt.
My recommendation would be to get an ARP crank bolt. First you need to seat the pulley all the way. IIRC manual states to install the crank pulley using the prescribed tool (Look on LS1 tech for a crank pulley installation tool, a VERY well spent $35), then using your OLD factory bolt, torque to 240 ft/lbs (this is hard, I have a helluva time every time I've done it). Then simply remove your old factory bolt and install the ARP Crank bolt and TQ to 190 ft/lbs. If you look at your factory bolt you should see red loctite on the threads.......I'd use it on the new bolt too.
Reason for recommending the ARP bolt is that it's reuseable.
To Help! Harmonic Balancer Bolt Issues
