I can't take it anymore..Help!!!
So far I have changed out in the following order:
Belt, Both Idlers, Both Tensioners, and that didn't work.
So today, I went ahead and changed out the alternator and put a new Gates belt on. I thought I had it fixed, but it came back about two miles down the road.
Weird thing is that it seems to only do it in a certain RPM range..such as 2K-4K.
Anybody have any other suggestions? It's driving me up the wall!!
Thanks.
Thanks.
I don't see where you changed the A/C belt. What happens when you run the engine without the main belt?
But I went ahead and changed out the main belt when I switched alternators. The other reason was that the car wasn't seeming to charge properly.
I changed the alternator today for a different issue, but was hoping it would maybe "kill two birds with one stone".
Thanks. I would hate to think it's a bearing somewhere. I have changed about everything that is somewhat easily accessible.
I would have to get someone to help though. It doesn't do it at idle, but only at a certain rpm.
This advice from E-T helped me when I had the problem:
Belt Squeal Courtesy E-T
You have two belt systems on your car. One is the drive belt system, the other is the air conditioner belt system. The drive belt system consists of the serpentine belt, the power steering pump, alternator/gen, water pump, harmonic balancer, idler pulley, belt auto-tensioner pulley. The AC belt system consists of the compressor, harmonic balancer, idler pulley, belt auto-tensioner pulley.
First thing you need to do is isolate which system is squeaking. This can be done by releasing tension on the drive belt tensioner and removing the serpentine belt. This is the outboard belt of the two belt systems. If the squeak goes away, then it’s the belt or a component of the drive system.
If the squeak is still there, then it’s a component of the ac belt system.
To verify this, release the belt tension from the tensioner and remove the belt. If the squeak goes away, then it’s a component of the ac belt system.
A common problem is the belt tensioner on either system but verifying which system is at fault is the proper procedure.
You could replace both belts, but you may still have the squeak. If you want to find the culprit, isolate the system, then spray the belt of the offending system and see if the squeak goes away. Try to stay away from the idler and tensioner while spraying. I find that belt dressing may be good to identify a belt problem, but it is a temporary fix at best.
The real problem has been the tensioner and the idler. Both of these components have a sealed bearing which has been know to dry up or redirect the grease away from the bearing, thus causing the squeak.
If you find that a belt change does not correct the problem, then a change of both the idler and tensioner pulley is in order. If you just change the idler or the tensioner alone, it will cause the other component to go bad in a month or so. This has been the case with many members. There was a change made to the dusts seals to help correct this problem in newer C5's. Lots of tensioner and idler pulleys have been identified as a problem and it can affect either system. One is not more prevalent than the other. So find out which system is squeaking first, in the drive belt system. It could also be the bearing of the alternator, power steering pump, or water pump too, but these are less probable.
I hope this makes things a little clearer
I hope that it isn't the crank pulley. A few months back, I did have the cam swapped and an underdrive pulley put on, but the squeaking was present before that.
I didn't get a chance to pull off each belt and run the car as I had to take 25 ten year-olds on a camping trip for a youth program in our neighborhood. Needless to say, no one got a chance to sleep.
HTH
