Tire Replacement
Old May 8, 2009 | 06:01 PM
cessna9109g's Avatar
cessna9109g
3rd Gear
Default Tire Replacement
Just replaced all four tires with Michelin Pilot Sport A/S ZP run flats on my 2002. When making a U-turn or hard right or left, they are rubbing the wheel wells. Anyone else had trouble???
Old May 8, 2009 | 06:06 PM
byronhunter's Avatar
byronhunter
It wouldn't hurt if you tell what body style, and what size tires you put on it?????????????
Old May 8, 2009 | 06:18 PM
cessna9109g
3rd Gear
2002 coupe; REPLACEMENT 245/45 17 front and 275/40 - 18 rear.
Old May 8, 2009 | 06:22 PM
byronhunter
That shouldn't be rubbing. Stock wheels? Car been lowered?
Old May 8, 2009 | 06:27 PM
cessna9109g
3rd Gear
No modifications to the car at all. Bought the tires from Tire Rack, were installed by one of their preferred installers, Big Brand Tires. They were on "close out". Thats why I was wondering if anyone else had problems with these particular tires
Old May 8, 2009 | 08:28 PM
BELVIN20's Avatar
BELVIN20
Just put a set my 2000 Vert, no problems, no rubbing. Just for grinns, look to see if the installer put a 18" on the front by mistake, not likely, but possible, I am sure you would notice if the installer had done that.
Old May 8, 2009 | 11:34 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Ever had it aligned? Could be a severe toe in or out? Bent tie rod? Bump steer? Hard to say without seeing it. Never seen anyone complain about Michelin PS tires.
Old May 8, 2009 | 11:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please post a picture of the issue. I have TOYO 315's on 19" CCW rims in the rear and I dont have any issues.
Old May 9, 2009 | 07:36 AM
rws.1's Avatar
rws.1
strange.... they have a narrower tread patch than stock as the corners are more rounded than the OEM GY's... should not be any issue.
Old May 9, 2009 | 11:35 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
they are not rubbing, that is a tire crying out for narrower wheels
Try to jack up the affected corners of the car, remove the wheel, and pinpoint the rub location. That will tell you about the cause.
While you are in there, make sure the tire installer didn't jack up the car at the wrong locations and bend something.
Old May 9, 2009 | 11:40 AM
coupeguy2001
BTW, Bill, you need to drive that car a little more. The rust on those discs is embarassing.
Old May 9, 2009 | 03:38 PM
Triton170's Avatar
Triton170
Just put a set on my 2000 Coupe and have no problems.
To Tire Replacement
