Climate control lights?
Old May 9, 2009 | 06:30 PM
chrisbenoit's Avatar
chrisbenoit
Default Climate control lights?
My climate control screen lights are extremely faint. I just bought the car and they were nice and bright then. Do I just have a button turned off, the dimmer switch is turned up, or do I have a light burned out or bad connection? Any help is greatly appreciated.
Old May 9, 2009 | 09:46 PM
glkfam's Avatar
glkfam
Default Dim lights
There is a problem with the lights going dim on the electronic A/C switch controller. Check the forum. The guys here did a great write up on how to fix this problem. If you are NOT handy, there are people here or I think even on eBay that will fix it for about $50 I think.
Old May 9, 2009 | 09:50 PM
glkfam's Avatar
glkfam
Default Just found this post
Found this post but I know there is a photo pictured blow by blow of how to do it.
Its fairly common
Heres an article I copied a while ago. The original has pics. Theres a vendor that fixes these things quite cheaply if you dont fancy the DIY
Climate Control Fading Fix
Written by Brad Moore with original instructions from fugedaboudit.
Pictures by Zach Walker.
1. Pry up the panel that goes around the shifter and pull it off, set aside (you don't have to disconnect the TCS wire - just lay that panel on the seat. The wire will extend far enough). After removing that, you'll see two bolts in the middle that go into the floor. Remove those.
2. Open the center console and take out the rubber bottom. It just sits on the bottom - no need to remove any screws. Under that rubber bottom will be two bolts which look the same as the ones in Step 1. Remove them.
3. Now look at where the center console piece and the dash meet. On the backside of this (down by the gas pedal) you will see a bolt on both the driver and passenger sides. Remove those two bolts. The entire center console should now be free to move.
4. Remove the ash tray to help gain a little bit of clearance. Pull the console unit back (start by pulling from the area where the dash and console meet), possibly pulling up and pushing down on the black part of the shifter unit (where it says PRNDL...etc). Just work it a little - enough to get the entire console moved back a few inches to get clearance for the climate control unit. (See Picture Below)
5. There are two phillips head screws holding the climate control unit in place. Unscrew those and remove the unit (disconnect the wiring also).
6. There are a few tiny bolts holding the plastic cover on the climate control unit. Take those out and pull the cover apart to reveal the circuit boards.
7. There are two circuit boards - one is the power supply and one is the display board. The display board is the one with the digital display built in - you do NOT need to mess with this board. I recommend not disturbing it much, as I dropped the plastic things that are behind the buttons and spent a long time trying to find them! Just unplug the connector that runs between the two boards and focus on the power supply board. The PS board is also held on by four bolts similar to the ones holding the climate control casing together.
8. Flip the power supply board over so that you are looking at the side that would be facing the rear of the climate control unit (I think. My memory is a little fuzzy on this one, but you'll find what you're looking for eventually). Look around the board for some small resistors (we think they are resistors anyways - they are flat and black) that have the number 241 on them. There are about 7 or 8 of them overall and bunched together. A few of them are a couple of inches away, but they are all in the general vicinity. These are the problem pieces. (See Picture Below)
9. Using a small soldering iron, touch the iron on one side of the resistor to melt the existing solder. Then add a little bit of fresh solder. Only add a little bit - that's all it takes! I generally added too much, so I had to mess around with picking that stuff up. A more experienced solderer would probably not have a problem with it. Also, if any of the resistors slides away when you do this, push it out of the way (keep it facing the same way that it was), apply a little bit of fresh solder on the contact points of the board, and then put the resistor back into its spot. Then, holding the resistor with a blunt object (toothpick, etc), melt each end into the fresh solder. Try not to keep the iron on the board too long - you could damage something.
10. Once done soldering, put the board back in the climate control casing and connect the two boards together. Go out to the car and connect the wiring harness to the unit, turn the car on, and see if it works. It should work now! I had problems at first because I didn't have the wiring harness from the car hooked up tight enough, so I was getting some strange results - so be sure that you have it plugged in tightly.
11. Once you are convinced it's working properly, put everything back together and you're all set!
Old May 9, 2009 | 09:51 PM
byronhunter's Avatar
byronhunter
You want help? Check this out!
http://forums.corvetteforum.com/c5-t...t=hvac+display
Old May 9, 2009 | 09:52 PM
glkfam's Avatar
glkfam
Default One more Post THIS IS THE ONE i WAS LOOKING FOR
CHECK THIS LINK OUT ALSO
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old May 9, 2009 | 10:14 PM
MagRedConv's Avatar
MagRedConv
Search it
Old May 10, 2009 | 08:03 AM
rws.1's Avatar
rws.1
those links are good if you are up to cold soldering yourself
If not
contact digitalguy_1@charter.net
aka David Ruberg about $50 with warranty...
Old May 11, 2009 | 04:15 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Or supporting vendor JW Motoring for $35...
Old Jun 11, 2009 | 02:49 PM
JJ the DJ's Avatar
JJ the DJ
Default Let there be light
Chris, the DIY tips work! Just take your time, don't force anything & use of a low watt soldering pencil is best. Keep the tip clean w/a damp sponge/rag & use a limited amount of solder.
I followed the step-by-step instructions & fixed the A/C display on my
Z16, this morning! Several resistors on the board were loose. A circular light with magnifying lens in the middle would have been handy.. those puppies are tiny.
BTW - big ADDA BOYS to glkfam, Genocid, England Green & all who posted DIY tips on this display problem. CF is awesome.
JJ
To Climate control lights?
