Battery for my 2004 C5?
Old Jun 11, 2009 | 07:42 AM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '07-'09
Default Battery for my 2004 C5?
Well my baby is 5 1/2 years old and it seems the battery is going. She turns over slower than normal.
I have looked on line and wanted to know suggestions on battery replacement.
Should I replace it myself? I am thinking yes. Is there anything I need to do before hand to protect the electical system?
What is the best battery for the money? I was looking at Optima's even though they seem a little pricey.
Suggestions!!
Old Jun 11, 2009 | 09:32 AM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Brad, mine went out while still under warranty, so GM gave me another Delco. I was going to get an optima, they seem to be the best. I'm sure you will get the yellow top.
Old Jun 11, 2009 | 09:46 AM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
It is covered with Stainless steel, but will still need the yellow one!!
Is there any protection I need to do or just disconnet and replace?
Old Jun 11, 2009 | 09:47 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
We keep Optima Batteries in stock.
$110 - Yellow Top 34/78
$105 - Red Top 34/78
$105 - Red Top 75/25
http://forums.corvetteforum.com/c5-p...ops-110-a.html
Seth
Old Jun 11, 2009 | 09:54 AM
LoneStarFRC's Avatar
LoneStarFRC
Just as a precaution, make note of your radio station pre-sets and make sure you have your radio unlock code handy. The procedure for unlocking the radio is in your OM.
Disconnect the Negative cable first and when installing your new battery, re-connect the Negative cable last. Any clicking sounds, etc you hear when connecting/disconnecting is normal.
BTW, that price that Hinson is selling the Optima 34/78 for is very good and no, I don't get any commisssion from them.
HTH
Old Jun 11, 2009 | 10:14 AM
jrose7004's Avatar
jrose7004
With an Optima most get the red top 34/78.
Old Jun 11, 2009 | 12:09 PM
waupachino's Avatar
waupachino
I would recommend an AC Delco Professional. I just had to take a Red Top Optima back with in a year and replace it under warranty with a AC Delco. The Red Top's don't like to sit for long periods and once they are discharged they don't like to hold charge.
Old Jun 11, 2009 | 12:26 PM
ljthe2nd's Avatar
ljthe2nd
Another vote for the AC Delco 7 yr professional. It's got a 50 month free replacement and the rest of the 7 years are prorated. The best battery warranty in the business. I bought one for my 04 for $108
I just put one of these in my car. I replaced an Optima Red Top. I would not recommend an Optima if your car is not a DD. Red Tops don't recover well if they become fully discharged.
The 04's are a top post, the problems people had in the past with batteries leaking and ruining the computer below were from over tightened side post batteries that caused the case to became cracked and leak onto the computer below. New batteries have a better case plus yours is a top post not prone to the problem.
Don't worry you won't loose your radio station presets or other seat or mirror memory functions, just disconnect the old and put in the new.
Old Jun 11, 2009 | 12:45 PM
LoneStarFRC
The 34/78 red tops and yellow tops have both terminals, side or top. Use the ones you need.
Old Jun 11, 2009 | 01:32 PM
TEXHAWK0's Avatar
TEXHAWK0
Since you do not have to worry about acid leakage, I would get the ACDelco Professional battery with 50 month free replacement warranty, and just change it yourself.
About the only thing you can do wrong is short out the terminals with a wrench, so disconnect the negative terminal first.
Old Jun 11, 2009 | 01:44 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Bob Steele Chevy in MI is quoting $128.95 for the 6yr battery. Is there any other places in the area to get a better price? I would be willing to drive 20-30 miles if needed.
Old Jun 11, 2009 | 02:01 PM
RyanR0101's Avatar
RyanR0101
Best warranty out there (not prorated after 2 years or whatever). I work with a guy who used to work for Johnson Controls, an OEM battery maker. He said in lab testing, AC Delco beat the pants off everything consistently. They are well built.
Old Jun 11, 2009 | 02:05 PM
jellyjam's Avatar
jellyjam
AC Delco 7 yr professional. That was my pick 2 years ago. Total cost with labor to find out what the problem was came to $150. The shop had a jumper battery on a wheeled cart and hooked it to the cables and changed the battery with no disconnect of power.
Have no problems since.
Old Jun 11, 2009 | 02:07 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
My local dealer is also stating that the 6yr battery only has a 18 month 100% replacement and then is prorated.
Anywhere I can get the true facts on the gm batteries and take into the local dealer if possible.
Old Jun 11, 2009 | 02:30 PM
Bill 70Coupe's Avatar
Bill 70Coupe
Your dealer is trying to sell you one of the 60 series ac delco batteries, stay away from those. The AC Delco professional series 7yr batteries have a 50 month free replacement. Check out www.acdelco.com it is the best battery you can buy for your C5.
Bill
Old Jun 11, 2009 | 02:52 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Bill
Thanks everyone for the help. I found a local A/C Delco dealer on MI who quoted me 133.95 for the 7yr 86 Pro battery.
Old Jun 11, 2009 | 03:04 PM
Dave68's Avatar
Dave68
....and yet another vote for the AC Delco Professional battery - highly recommended!
To Battery for my 2004 C5?
