Help! Reduced engine power!
Old May 10, 2009 | 11:50 PM
acarroll7715's Avatar
acarroll7715
Default Help! Reduced engine power!
My z threw the "reduced engine power" today and is super tripping out. Here's a list of codes
PCM:
P1626 Theft Deterrent System Fuel Enable Circuit
TCS:
U1301 Class 2 Circuit Shorted to Battery
BCM:
U1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
SDM:
U1301 - ?
IPC:
U1040 Loss of Communications with TCS
U1064 Loss of Communications with BCM
U1088 - ?
U1176 Loss of Communications with RFA
U1160 Loss of Communications with LDCM
Radio:
HVAC:
U1160 - ?
B0361 Left Actuator Feedback Short to GND
B0441 Left Actuator Out of Range
LDCM:
RDCM:
No Comm.
SCM:
U1300 - ?
BO-RFA:
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Someone help
Old May 19, 2009 | 08:06 PM
VetteC5Z51's Avatar
VetteC5Z51
I just fixed this problem today. Check out this thread, it will explain how to fix the problem. About half way down the thread there are link to two pictures of what you are looking for that are very helpful. Good luck
http://forums.corvetteforum.com/c5-t...ine-power.html
