what exhaust to emphasize cam?
Old May 16, 2009 | 12:26 AM
TrchRedC5's Avatar
TrchRedC5
Default what exhaust to emphasize cam?
01 zo6 with a farily big cam
lg streets, no cats and b&b bullets. these bullets sound great but they are sooooo deep that it takes away from the chop of my cam. i drove my car yesterday and after it got good and warm it sounded like it barely had a cam in it. from what i've heard the b&b prt's sound good with a cam, and i think indy pace? sounds good too. what do you guys think? i want to change my catback to bring that cam sound out?
Old May 16, 2009 | 01:22 AM
black98c5's Avatar
black98c5
Cut-outs!!!!!!
Old May 16, 2009 | 08:10 AM
AU N EGL's Avatar
AU N EGL
think you have it up to the exhaust.
Borla Stingers
GHL - bullets - give deep rumble tone at ideal
B&B kind sounds like a motor boat
Corsa indy pace will quite down what you have
BTW, what are your cams specs?
Old May 16, 2009 | 11:06 AM
TrchRedC5's Avatar
TrchRedC5
i like the deep rumble, but deep rumble takes away from the chop. i want the chop back.
Old May 16, 2009 | 11:48 AM
AU N EGL's Avatar
AU N EGL
236/240
lift and LSA.
Deep rumble is more with cams LSA then exhaust.
if your running a 114 lsa or larger, there will be some but not a lot
I run a 224/224 581/581 on a 112+0 ppl think I have a bigger cam then it is.
Friend has a WC cam 106+3 lsa now that sucker rumbles
Old May 16, 2009 | 01:45 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I'm running a slightly bigger cam 239/243 with LT headers and went through a number of exhaust systems before sticking with the GHL Bullets (tried the Borla, B&B and Z06 Ti) - it gives you the great sound from the cam without the annoying drone. Great quality too!
Old May 17, 2009 | 08:42 AM
AU N EGL's Avatar
AU N EGL
GHL Bullets would be a great choice
Old May 17, 2009 | 09:01 PM
TrchRedC5's Avatar
TrchRedC5
AlohaC5 is there any chance i can get a video clip of your car could i?
also, not to get into a long story, but i installed my cam a few degrees retarted. i was supposed to put it in at 111 and my tuner thinks it is a few degrees late. i'm about to get back into it and get an adjustable timing set and having someone degree it. if i find it was put in late, and then i correct it going in at 111, will the idle change?
Old May 17, 2009 | 09:12 PM
Gray Ghost GS
I'll record some video for you tomorrow after work so you can hear the exhaust. My cam LSA is 113+3. I don't believe adjusting the degree of your cam will change your RPM idle settings.
Old May 17, 2009 | 11:05 PM
TrchRedC5's Avatar
TrchRedC5
that would be awsome if you did that. i know it wouldn't change the rpm of the idle, but i was wondering if it would change how it sounds... i don't do this for a living so i don't know a ton of this stuff. the grind of the cam wont change. but if i had the cam installed at 114 degrees and then changed it to 111 degrees. would that make the idle choppier just as if 2 same cams ground at 114 and the other 111. the 111 would idle more aggressive.
Old May 19, 2009 | 09:06 PM
Gray Ghost GS
Here's a 2 minute clip of the sound of my exhaust so you can hear the cam at idle and at approx. 2000 RPMs through my GHL Bullets (toward the end of the clip) - hope it helps. Sounds like stock. Mike
To what exhaust to emphasize cam?
