Engine shut down....
Old May 11, 2009 | 01:33 PM
alshirey's Avatar
alshirey
Default Engine shut down....
Here's the short of it. Was getting on the highway, down shifted from 4th to 3rd. Just as I did and the RPM's shot up, an odd sound (only way I can think to describe it would be a POOF) and then NOTHING from the engine. I pulled over in the merge lane and car would not restart. Had it towed to a mechanic and he has yet to really take a good look at the car, however he did notice that the one accessory belt had ripped. It's not the main belt in front that drives everything, it's the belt behind that drives the AC compressor.
Would this belt ripping cause the engine to shut down? I can't believe it would, so is there anyting within the vicinity that would be destroyed by the belt ripping and cause the engine to shut down?
Thanks.
Old May 11, 2009 | 01:37 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Sounds like you went to 1st and overrevved.........open your wallet if that's the case.
When you tried to restart did is sound normal?
Old May 11, 2009 | 01:41 PM
dougbfresh's Avatar
dougbfresh
Bet you bent some pushrods and maybe a valve hit a piston. Pull the valve covers and take a look-this is probably going to hurt.
Old May 11, 2009 | 03:17 PM
alshirey's Avatar
alshirey
NO....I know it was 3rd gear...there was time to let the clutch out and get the RPM's up. Definitely not even close to putting it in 1st. Thanks for the help, I guess I'm trying to concentrate on finding out if the AC belt can wipe anything out...some sensor or what might be in that area.
Car would not restart or attempt to restart....starter was trying but nothing.
Old May 11, 2009 | 03:38 PM
timemender's Avatar
timemender
Retrieve and post the codes: Always a good place to start when diagnosing.
So you’re saying that you know for sure that the engine did NOT over rev past redline? (As it would if you shifted into first)
Old May 11, 2009 | 05:25 PM
alshirey's Avatar
alshirey
Don't get me started on this, but the mechanic was iffy about me reading codes....says he doesn't want to wear the battery out. I know, I know....
YES...I do know what shift to 1st would've been like. NO, I did not shift to 1st. There was a very short burst of acceleration before the engine quit. YES, I have hit the rev limiter before and NO I did not hit it this time.
I DID NOT SHIFT INTO 1ST. Whether I broke/bent a rod or any other catastophic failure happened....It wasn't because I shifted to 1st. I understand I might not have been clear that the RPM's went up when I down shifted, but it wasn't because I shifted to 1st.
We can hopefully get past that and focus on what the AC belt could've wiped out. THANKS.
Old May 11, 2009 | 05:36 PM
nickolbag's Avatar
nickolbag
Reading the codes wont wear the battery out. It literally takes a minute to do and could easily provide info to resolve the problem. Without pulling codes its all specualtion.
If you broke/bent a rod you would know it. There would be awful noises and "poof" isn't one of them.
Old May 11, 2009 | 05:52 PM
lucky131969's Avatar
lucky131969
Don't get me started on this, but the mechanic was iffy about me reading codes....says he doesn't want to wear the battery out. I know, I know.....
Find a new mechanic if he's worried running the battery down on a car that won't start....
YES...I do know what shift to 1st would've been like. NO, I did not shift to 1st. There was a very short burst of acceleration before the engine quit. YES, I have hit the rev limiter before and NO I did not hit it this time..
And that's why everyone keeps thinking you hit 1st, there is no rev limiter protection for this....
You said the belt was ripped. What does that mean? Still on the pulley, hanging, etc?
Unless the belt wrapped itself around some wire harness, who knows. Last time I was in a car that made a "poof" noise while acceleration, and shut down/no restart, it was a timing chain.
To Engine shut down....
