Anyone running a vacuum pump?
Old May 13, 2009 | 02:50 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Default Anyone running a vacuum pump?
http://www.gzmotorsports.com/LSXVPK.html
Thinking of picking one of these bad boys up, wondering if anyone is running one, specifically on a NA build.
Old May 13, 2009 | 03:06 PM
lucky131969's Avatar
lucky131969
Why, are you running a 1200 hp engine that has no pcv system or adequate venting of he crankcase?
Old May 13, 2009 | 03:15 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Something like that
No, I'm just wondering if it would help oil consumption issues.
Old May 13, 2009 | 04:00 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
im doing or going to....get one. my LS3 416 jsut eats oil. I think it is blow by, but im still working bugs out. the PCV is all custom..
I have hooked it up 70000 different ways, and so far the best way has been...
i took the valley cover and modified the outlet tbe to be more open to release more air. I now use an external valve to a catch can. The smoking on accel and decel has greatly improved. a 800$ vac pump is the last resort. They also scare me becuase you need to run one around 17-19. To much vac and you can starve your bearings and smoke your crank
Old May 13, 2009 | 04:21 PM
Mike94ZLT1's Avatar
Mike94ZLT1
My 382 loves oil. Who built your 416? I read some more on that pump, its not designed for street use / daily driving.
Old May 13, 2009 | 07:56 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I just talked to Greg, the gentleman that makes these pumps. He is warrantying them on GEN III and GEN IV motors! That was kind of a hang up for me, I wasn't about to drop $800 on a pump with no warranty.
Old May 14, 2009 | 09:39 AM
chevy406's Avatar
chevy406
I have one of Greg's setups on my SBC 406 in my '69 Nova. When I built that engine, I opened the rings up quite a bit for nitrous. It allows quite a bit of pressure into the crankcase, and I was blowing my oil dip stick when I made nitrous runs at the track. Now, with the vacuum pump I have zero oil leaks. I hope to get it on a dyno to quantify the power it is supposed to add. I have driven my Nova quite a bit on the street, and the vacuum pump is holding up just fine. I have considered one for my FRC also, but can't really justify it.
Here is a picture of my setup that Greg posted on his site (the first two pictures are my engine): http://www.gzmotorsports.com/sample-installations.html
Old May 14, 2009 | 10:04 AM
VGLNTE1's Avatar
VGLNTE1
how long is the warranty. and im pretty sure you can daily drive them
VGLNTE1's Avatar
VGLNTE1
scoggin dickey
Old May 14, 2009 | 10:42 AM
95BlueBomber's Avatar
95BlueBomber
I have been wanting a vac. pump on my car for a while. The problem is I dont have a mounting spot because of the supercharger. Jegs has an electric vac. pump kit on their site. Anyone tried this?
Old May 14, 2009 | 12:13 PM
Mike94ZLT1's Avatar
Mike94ZLT1
12 months. I wonder what he would charge for a pump rebuild? I only drive my car in the spring, summer and fall, and could easily pull it off come winter time and send it in for a freshening!
Old May 14, 2009 | 12:53 PM
Slow Z06's Avatar
Slow Z06
Racetronics makes a harness to turn your factory air pump into an engine evac pump. I know it is meant for boosted aplications due to running off a hobbs switch.
Old May 14, 2009 | 01:15 PM
95BlueBomber
Interesting... I dont think the air pump would move enough to actually create vacuum though. I want a little vacuum to create better ring seal on my car. I might have to make a harness for my air pump though and try it.
Old May 14, 2009 | 01:25 PM
2000BC's Avatar
2000BC
I fabricated an auxillary vacuum system using an electric vacuum pump in my 77 Vette but not for crankcase evacuation but for running all the vacuum systems. The engine was a bit too radical (Lunati cam Brodix heads etc) and didn't develop enough vacuum to even lift 1 headlight. Worked great, no problems, just was fairly loud when I hit the switch to turn it on. Probably wouldn't last if you ran it full time. I only had to turn it on for short intervals.
Old May 14, 2009 | 03:47 PM
VGLNTE1's Avatar
VGLNTE1
i looked into this as well. I read it only creates 1-3 units of vac compaired to the 15-16 we should use
Old May 14, 2009 | 07:11 PM
Mike94ZLT1's Avatar
Mike94ZLT1
The kit I posted has an adjustable bleed valve, so you can set the amount of vacuum. If you can set it to the proper level I wouldn't worry about it starving the bearings.
Old May 15, 2009 | 08:40 PM
Blorton's Avatar
Blorton
It's too bad the header venturi vacuum option wouldn't be practical for us.
To Anyone running a vacuum pump?
Old May 18, 2009 | 02:50 PM
Mike94ZLT1's Avatar
Mike94ZLT1
That would make a huge mess! I ran into a guy running one of these pumps on an old gto yesterday, and he had a pretty trick oiling system set up. I think I am going to try and duplicate it.
Old May 18, 2009 | 03:39 PM
Slow Z06's Avatar
Slow Z06
Keep us up to date to your progress. I as well as many, would like to find a good solution to the vac problems
Old May 18, 2009 | 05:34 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I have some pretty sweet plans that should work, based off the system that I saw yesterday. I need to relocate my battery, unless I can find a good spot for 2 reservoirs. One for an oil feed for the pump, and one to use as a catch can to put the condensed oil vapor. I could go further and make a recirculating system, but I want to try it with 2 tanks first. I need to find an economical way to move that battery. Summit has a kit that is about $80, I just want to make sure the box fits one of thise side wells in the back. I also need to know if I can ground to the frame with the battery's negative cable.
