magnaflow catalytic converters
Old May 14, 2009 | 04:52 PM
eelstx's Avatar
eelstx
Default magnaflow catalytic converters
I have 185,000 miles on my 01 Vette now and I may need to replace the catalytic converters. Code PO430 catalytic system low efficiency comes up when I poll the codes. I've been quoted $2100.00 installed for factory set. I see where Magnaflow has a set Model #93988 for $398.88. Is this system worth the trouble to order and have someone install or should I bite the bullet for factory cats? Any feedback would be appreciated.
Thanks,
eelstx
Old May 14, 2009 | 05:34 PM
The Wrench's Avatar
The Wrench
Sure, the Magnaflows should be fine, and they are not very hard to install. Another even less-expensive option is to buy a used midpipe/cat section from a forum member. Lots of the guys here switch to headers and hi-flow cats, and sell the old midpipe/cats at very reasonable prices. Check the parts-for-sale section, maybe place a want-to-buy post. Any 2000-2004 will bolt right on your '01. the Z06 ones are best, cause they don't have the little pre-cats.
DG
Old May 14, 2009 | 05:58 PM
BUGZ's Avatar
BUGZ
$2100 is way high. I also attempted to go with the Magnaflows, but they don't make one that fits a 99. (their site says they have one, but it does not) Been there done that. Any who... I had a reputable performance shop quote me $640 bucks to drop the exhaust, cut out old cats, weld in new ones that were California Smog Compliant and reinstall exhaust. Never followed through with it. I just installed some 02 sims. If I ever sell her, I'll replace the cats then.
btw - a factory mid-pipe w/cats is about $1K at the dealer (not installed).
Old May 14, 2009 | 06:17 PM
chevylad's Avatar
chevylad
another member just showed me this link:
http://www.performance-curve.com/ind...OD&ProdID=1181
$55 bucks a convertor. I couldn't rememeber if the stock cats were 3 or 2.5 inches. I think the inputs are three inch and the outputs are 2.5. If that's the case a 2.5 would work at shop a muffler shop that can weld stainless.
Old May 14, 2009 | 06:59 PM
sami85L98's Avatar
sami85L98
2.5" in/out.
Old May 14, 2009 | 08:40 PM
kettemr's Avatar
kettemr
I have an '01 with 30k miles and my cats went bad two weeks ago (ratttling). The internal honeycomb came lose.
The dealer quoted $1,550 including $87 labor for OEM replacements. I researched and found Magnaflow high flow cats which I bought. I also bought the Magnaflow X-Pipe. These two pieces replace the one piece factory cats and H-pipe assembly.
You can get away with the cats only and have a shop cut the factory exhaust and weld the H-pipe to the Magnaflow cats. I figured by the time I paid them to do that and install it, I may as well upgrade the entire system to include the Magnaflow X-Pipe. Its all being installed tomorrow at my local Monro.
I shopped around and bought mine from AutoAnything.com. They had an offer going last week for $20 off every item over $200 so I saved $40 bucks on the package. Shipping was free and no sales tax. Cost for each piece were as follows:
Cats - $369.58
X-Pipe - $329.17
Total - $698.75
Est Labor - $90.00
I will re-post tommorrow after they are installed. I'm running this back to a Z06 Ti cat back.
Old May 16, 2009 | 10:59 AM
kettemr's Avatar
kettemr
UPDATE:
I went to have the new parts installed and the Magnaflow catalytic converter that I received is defective in that the two pipes don't line up with the exhaust manifolds correctly. I am working on exchanging for a new part and will advise when it is finally installed.
Old Feb 4, 2013 | 09:22 PM
WannaC5Z's Avatar
WannaC5Z
Originally Posted by kettemr
UPDATE:
Whatever happened with this? I have read another thread where the Magnaflow didn't line up correctly. Wierd cause they always fit good on my 86 Mustang GT and 97 Cobra.
To magnaflow catalytic converters
