no abs! how?
Old Jan 29, 2013 | 06:41 PM
blkdevl's Avatar
blkdevl
Default no abs! how?
goin to get rid of my abs.. what r any of u doin for routing or proportion valve setup?
thanks
Old Jan 30, 2013 | 01:22 AM
blkdevl's Avatar
blkdevl
this in on my drag 2000 cpe
Old Feb 1, 2013 | 12:47 AM
blkdevl's Avatar
blkdevl
ttt
Old Feb 2, 2013 | 06:55 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I took mine off,Brakes work alot better now.Also took out the ABS fuses and took out the ABS & Traction control light bulbs from the dash.Took out the EBCM,Got a 3 way adapter on the single rear brake line and ran my own brake lines to the rear wheels,Also ran my own brake lines from the line loc to the front wheels.The only message I get is SERVICE ENGINE SOON and I have to hit reset.I can live with that
Old Feb 3, 2013 | 11:23 AM
blkdevl's Avatar
blkdevl
thanks bro
Old Feb 4, 2013 | 10:01 PM
92GA's Avatar
92GA
Oldtimer
I removed the abs on my sons 96 Firebird drag car. I bought the proportion valve at summit racing. Thing is you will have to change the fittings on all the brake lines to do so. I removed all the brake lines and took them to a shop that makes brake lines to have the correct fittings installed. We used the original master cyclinder. They work great, but we are only running in a straight line.
To no abs! how?
