Exhaust question??
Old May 14, 2009 | 09:32 PM
thetitan's Avatar
thetitan
Default Exhaust question??
I was looking at a local set of Dynomax Ultra Flo Cat Back mufflers for a 98 Coupe. The inlet pipes are welded together and welded to the mufflers and the tail pipes are also welded to the muflers.
Will this cause a problem with installation, or will I have to remove any parts from the car? The owner of the exhaust said it will easily bolt on.
Thanks for the help.
Old May 14, 2009 | 09:46 PM
c5blkvetteguy's Avatar
c5blkvetteguy
With it all welded together you will have to drop the rear sway bar and have it very high. If you have a lift, or can use one, thats the way to go.
Old May 14, 2009 | 09:58 PM
thetitan's Avatar
thetitan
IS it a big deal to drop the sway bar?
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
FRICK!!!!! with all that welded ,,,,,,,,you may have to drop the ENTIRE drive train!
BC
To Exhaust question??
