Alignment specs??
Old Feb 5, 2002 | 01:20 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Alignment specs??
Can anyone post alignment specs for 2002 coupe and 2002 Z06. Thanks
Old Feb 5, 2002 | 03:05 PM
RoliO's Avatar
RoliO
Default Re: Alignment specs?? (Glennm27)
Here is a copy of the Z06 specs from Ken Fitchner's weekly newsletter :cheers:
Z06 Wheel Alignment Specifications
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe +0.14 to –0.06 degrees +0.04 degrees
Front Sum Toe +0.28 to –0.12 “ +0.08 “
Front Individual Camber +0.50 to –0.70 “ -0.20 “
Front Cross Camber +/- 0.25 “ within 0.50 “
Front Individual Caster +6.4 to +7.4 “ 6.9 “
Front Cross Caster +/- 0.25 “ within 0.50 “
Steering Wheel Angle +1.0 to –1.0 “ 0.00 “
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe +0.09 to –0.11 degrees -0.01 degrees
Rear Sum Toe +0.18 to –0.22 “ -0.02 “
Rear Thrust Angle +0.10 to – 0.10 “ 0.00 “
Rear Individual Camber +0.32 to –0.68 “ -0.18 “
Rear Cross Camber -- within 0.50 “
Old Feb 5, 2002 | 03:44 PM
Glennm27's Avatar
Glennm27
Default Re: Alignment specs?? (RoliO)
Thanks :D
Old Feb 5, 2002 | 04:25 PM
MySea6's Avatar
MySea6
Check your email
Old Feb 5, 2002 | 07:02 PM
Glennm27's Avatar
Glennm27
Default Re: Alignment specs?? (MySea5)
Got it! Thanks alot Ken! :cheers:
To Alignment specs??
