Can i porte ls6 intake
Old May 17, 2009 | 10:13 AM
baezi z06's Avatar
baezi z06
Default Can i porte ls6 intake
Can i porte my Ls6 intake manifold and use my ls6 throttle body..
does that work, or do i haveto get new throttlebody to have it work like it should after it is porte the intake
Old May 17, 2009 | 10:33 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
The LS6 flows very well (better than the LS1 and LS2) - you might want to consider adding a 90mm TB to your LS6 intake. TPIS offers a service where they modify the LS6 intake manifold for $350 so you can fit the larger GM LS2 90mm TB for improved air flow, etc.
To answer you original question. I wouldn't attempt to port the LS6 intake. If you want to maintain the 78mm TB - I recommend having it ported and polished. I had mine done before moving up the the FAST 90/90 and was happy with its overall performance for the the cost.
Old May 17, 2009 | 03:45 PM
baezi z06's Avatar
baezi z06
what about LS2 intake/throttleb. are they better ported...
To Can i porte ls6 intake
