Drivers Window - Tech Help Needed
Old May 17, 2009 | 03:01 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Default Drivers Window - Tech Help Needed
Hi..the drivers side window is making wierd noises when travelling up/down...It still operates but there is a noticeable grinding noise noise. I'm afraid to use it for fear that it will get stuck in the down position...before I remove the door panel does anyone have any suggestions or experience with what the problem may be??
Old May 17, 2009 | 03:09 PM
byronhunter's Avatar
byronhunter
Is it scratching the window glass? If not, check for a frayed cable. Strickly speculation at this point.
Old May 17, 2009 | 03:25 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Glass is fine with no scratching evident...
Old May 18, 2009 | 06:17 PM
TEXHAWK0's Avatar
TEXHAWK0
http://www.regulatorusa.com/product_...41&product=122
You will probably just have to inspect the window regulator assembly for signs of frayed cables, worn pulleys, etc.
I had one window make a rattling noise and I never did find anything that looked wrong. I thought it might be the drive gears, but they also looked fine.
I finally ended up replacing the window regulator assembly.
If you do not want to spend $200 or $300 for a new assembly, you can have them rebuilt at regulatorusa.com. They also sell rebuilt ones on eBay.
Old May 18, 2009 | 06:49 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Thanks for the info!! just what I needed...
To Drivers Window - Tech Help Needed
