Centering steering wheel
Old May 19, 2009 | 02:20 PM
puzzleboy's Avatar
puzzleboy
Default Centering steering wheel
What's involved with centering a steering wheel? My car had an alignment done last year, and the wheel is slightly off. Alignment is good however.
On my Jeep, I just shorten/lengthen the drag link to center the wheel. Is there a similar adjustment on a C5?
Thanks!
Old May 19, 2009 | 06:19 PM
byronhunter's Avatar
byronhunter
"Is there a similar adjustment on a C5?"
Yep.
Old May 19, 2009 | 09:15 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It needs to go back to the alignment shop and be done correctly. They've set the toe off by not having the steering wheel properly centered. I'm not an alignment expert.
Old May 20, 2009 | 11:25 AM
RogerZ06's Avatar
RogerZ06
You need alignment. I had same problem.
Old May 20, 2009 | 12:56 PM
TEXHAWK0's Avatar
TEXHAWK0
After the caster and camber are set, you always set the toe-in last and center the steering wheel by taking out equal amounts on each side.
To center the steering wheel you would need to lengthen the tie rod on the side the steering wheel is off, and subtract an equal amount to the tie rod length on the opposite side.
You point the wheels to the side the steering wheel is off so that when the wheels come back to center, the steering wheel will also return to center.
Old May 21, 2009 | 02:58 PM
puzzleboy's Avatar
puzzleboy
O.k., two different answers. Obviously, it's not the same as my other car which links the two wheels by the tie rod. On that one, you simply loosen/lengthen the drag link to center the wheel. Very easy.
So because it's off such a slight amount, I can loosen and tighten opposite sides an equal amount until it's centred?
Thanks!
Old May 21, 2009 | 05:52 PM
Miker6's Avatar
Miker6
it will probably need to realigned. it does not mean that toe is off. toe can be set right and the steering wheel not be centered.
Old May 21, 2009 | 10:20 PM
TEXHAWK0's Avatar
TEXHAWK0
This is true. The toe-in may be correct, but they just did not adjust the tie rods equally to keep the steering wheel centered.
A tie rod comes out of each end of the steering rack. You will have to shorted one, and lengthen the other to center the wheel.
Usually the steering wheel gets off center because the shop makes all the toe-in adjustment on one side instead of equally from both sides.
Old May 22, 2009 | 06:51 AM
rebelheart's Avatar
rebelheart
To late after a year to go back and have the shop do your alignment properly,I would not try to do it yourself,get it realigned some where else!
To Centering steering wheel
