fast 90 install
Old May 19, 2009 | 05:59 PM
dpw41285's Avatar
dpw41285
Default fast 90 install
i have heard mixed results on this. some say no modifications are needed and some say you have to do a firewall mod. this is on my 01 coupe. can you clear this up for me!!!
Old May 19, 2009 | 06:30 PM
vettenuts's Avatar
vettenuts
That is for the MAP sensor. I installed an elbow and moved the MAP sensor around the corner. LPE also makes a relocation kit. With the options available, there is no need to modify the firewall on the car.
Old May 19, 2009 | 07:33 PM
dpw41285's Avatar
dpw41285
thank you now if i could just find a decent priced ls2 tb
Old May 19, 2009 | 10:50 PM
06x6spdGTO's Avatar
06x6spdGTO
If you have the Coolant Crossover on the rear you need to delete it otherwise the intake wont fit/seal correctly.
the delete kit consist of special oval blocks. Call FAST and they should be able to direct you to a Rear Coolant Crossover Delete Kit.
But if you want to be cheap you can just cut the pipe close to the stock blocks on each side. then abraise whats left of the piping shut.
Old May 20, 2009 | 08:44 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I installed a FAST 92 on my 99. I did replace the cooling tubes under it. The two rear ports have plugs now, and the front just has a lone between them, with a 'T' fitting.
My MAP sensor fit fine in the hole in the rear of the manifold. I used RTV to seal it, and hold it in place, since it did not have the same setup as the factory manifold. I've had my manifold off the car several times, and the MAP sensor is still rock-solid.
Old May 20, 2009 | 04:06 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I used the LPE relocation kit for the MAP sensor
Old May 20, 2009 | 05:31 PM
dpw41285's Avatar
dpw41285
Any one have a link on this los I checked the site with no such luck
To fast 90 install
