upgrade my suspension!
Old May 21, 2009 | 08:22 AM
SIC VET's Avatar
SIC VET
Default upgrade my suspension!
ok whats diffrent between the z51 option and z06 in the c6 model? with the z6z06 springs and sway bays bold right into a c5 coupe? and would the be the best route to take? i dont want to spend a ton to money!
Old May 21, 2009 | 08:46 AM
ljthe2nd's Avatar
ljthe2nd
The difference between the Z51 and Z06 springs and sway bars is the ZO6 springs are stiffer and the sway bars are larger in diameter. Yes they will bolt up directly to your C5.
In a thread published here months ago one of the owners of Pfadt racing, a vendor here and manufacture of some excellent suspension parts for racing and the street, responded to a question similar to this saying that for the C5 unless you put on wider wheels and tires the best fit for the C5 was C6 Z51 sway bars. A lot of forum members have put the C6 Z51 sways and either Bilstein shocks or C6 Z06 shocks and left the stock C5 springs on their cars and been very happy with this combination. This would also be the cheaper way to go, and you might be able find some of the stuff used in the C6 Parts forum.
Old May 21, 2009 | 09:20 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^I was thinking along similar lines. From the OP's profile looks like he has a 98. Might want to look at C6 Z06 shocks and C6 Z51 sway bars from Gene Culley (he's a supporting vendor on the forum). I think the shocks are around $240 and the bars around $200. Buy some used
C5 Z06 springs and your ready to go!
Don't forget to take the car to suspension shop and have them properly set-up the suspension for you.
Old May 21, 2009 | 09:25 AM
MattB's Avatar
MattB
IMO unless you have specific needs I would go the route of the previous poster. C6 Z51 sways and C6 Z06 shocks. Leave the springs for last. I would go with a softer spring, the ride will be better. The shocks and sway bar will be a huge improvement without causing a harsh ride. I'd contact Gene @ www.gmpartshouse.com
Old May 21, 2009 | 06:28 PM
SIC VET's Avatar
SIC VET
k thanks everyone, and i am running a wider tire in the rear, ccw's 19x11.5
Old May 22, 2009 | 08:33 AM
rmtt's Avatar
rmtt
What size tire? I have some 19x11's and wondering if a 305/30/19 will work/clear on my lowered FRC.
Old May 22, 2009 | 09:52 AM
SIC VET's Avatar
SIC VET
assuming your backspacing it the same as mine ya, mine is lowered alot! and thats what im running and its fine!
To upgrade my suspension!
