Mixing brake fluids.
Old May 21, 2009 | 01:31 PM
HWY HNTR's Avatar
HWY HNTR
Default Mixing brake fluids.
Can I mix DOT3 with DOT4? Thanks.
Old May 21, 2009 | 04:12 PM
Last C5's Avatar
Last C5
Yes, most newer DOT 4s are compatible with the 3s. I use ATE Type 200 (clear) and ATE Super Blue (blue duh) and I've mixed both those, in the process of changing over, with various DOT 3s that were in the cars originally.
Old May 21, 2009 | 07:07 PM
HWY HNTR's Avatar
HWY HNTR
Thank you sir. So I can mix the two for the clutch fluid too I assume.
To Mixing brake fluids.
