Does Amsoil 75w90 require friction modifier?
Old May 21, 2009 | 09:14 PM
T_Vert's Avatar
T_Vert
Default Does Amsoil 75w90 require friction modifier?
It says to add it if you experience clutch chatter. What are you guys doing? I know many synthetic fluids come w/ the modifier already installed.
Dave
Old May 21, 2009 | 09:28 PM
sami85L98's Avatar
sami85L98
May be it comes with it, but it dont hurt 7-8 bucks bottle from GM, i added 1 4Oz GM friction bottle along with RP 75W90 last year and still had no problem and rear end is happy and iam happy.
Old May 21, 2009 | 09:37 PM
donkelso's Avatar
donkelso
I just changed oil in my diff with AMSOIL 75W-90 and did not use any modifier. My diff does not have any chatter. Recommendation I got from an AMSOIL distributer on the forum recommended to try it without and it seems fine.
SaberD's Avatar
SaberD
GM came out with a new differential fluid with the correct amount of friction modifier already premixed. the part # is 88862624. this is the stuff they use in the c6 and its supposed to be the best. i put it in my diff and it works great!
Old May 21, 2009 | 09:56 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 comes with friction modifier already in it and extra is not normally needed in C5s to prevent diff chatter. I use this fluid without extra additive in both my 02 C5 Z06 track car and in my 06 Cadillac CTS-V and neither diff chatters.
That said, the C6 seems to need a bottle of AMSOIL Slip-Lock Differential Additive.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 23, 2009 | 07:37 PM
T_Vert's Avatar
T_Vert
Thanks. I didn't use it when I put in redline last time either.
Dave
To Does Amsoil 75w90 require friction modifier?
