Manaul to Auto Conversion Wiring HELP Please
Old May 22, 2009 | 05:18 PM
Z06KID's Avatar
Z06KID
Default Manaul to Auto Conversion Wiring HELP Please
Does anyone know who switched over from manual to auto on a 2002 Z06 C5. I need help as far as what wires that I need to tap into and run and shift properly. Its a race car and no need for reverse lights or brake pedal to put in gear. Do i Need to run a netural safety switch if I use a race ratchet shifter?????
Thanks to everyone who can help me.... Please lots of detail or pictures
Old May 22, 2009 | 05:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like you should have installed a tranny controller. If you don't hook everything up using the stock sensors, parking, etc .... You're going to have a lot of problems.
Are using a manually shifted tranny ?
Old May 22, 2009 | 06:37 PM
Z06KID's Avatar
Z06KID
already got a trans cooler so that takes care of that just need some help more help!
Old May 23, 2009 | 01:28 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
let me know if you need any A4 harness parts
Old May 23, 2009 | 07:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I did the conversion but I need a little more info from you to help.
What year car, model, etc ... Did you use an A4 harness ?
To get the car to crank (start) you'll need to run the purple & yellow wire from the clutch safety switch to the rear selector switch unless you don't care and then you can just connect the two together and the car will start anytime the key is turned, (i.e. no safety)
Old May 25, 2009 | 01:27 PM
Z06KID's Avatar
Z06KID
thank you for your help I dont care if the car can start anytime key is turned so all connect them thanks. the car is an 02 I have the 02 wiring harness . I dont need the car to be in park to start or any of that safty stuff I have no problem shifting the car manualy. I just need to know if I can just not run the neutral safty switch and do I need to do any wiring in the car?
Old May 25, 2009 | 04:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What the purple and yellow wire do at the clutch safety switch is the same as the automatic except that they are located on the switch in the back (Gear Selector Switch Indicator).
So by jumping them together you eliminate the park safety switch. Car should fire right up.
THe work that is needed (wiring) is for the PCM to control the tranny. Based on your purpose you might want to go with a stand alone controller box. It will probably save you a lot of headache.
Tony
To Manaul to Auto Conversion Wiring HELP Please
