fuel pump problem
Old May 22, 2009 | 08:42 PM
Blow Torch's Avatar
Blow Torch
Default fuel pump problem
Anyone have any "tips" to properly installing a fuel pump? I am having fuel delivery issues that I need to make SURE is not a result of the filter sock not fully "extended". I have installed the same pump twice, and I am still having issues with fuel delivery problems at wide open throttle. (dropping to 47psi)
I actually HOPE it turns out to be a bad pump, but if not why am I having trouble getting it in right??
And to add to the problem, I've got a stripped bolt hole on the tank that I'm going to try and repair with the locktight thread repair if someone has used it before
Old May 23, 2009 | 11:18 PM
Blow Torch's Avatar
Blow Torch
No one?? So I'm the only one that had trouble getting that puppy back in correctly (or have a bad pump) and stripped one of the TINY bolts when trying to torque?
Old May 24, 2009 | 08:43 PM
Armycop's Avatar
Armycop
I'm sure you're not alone with this. I've done my fuel pump twice now, and my sender once. Haven't stripped a bolt though (so far).
To fuel pump problem
