Trans Shift Detent Bolt
Old May 23, 2009 | 02:30 AM
MTPZ06's Avatar
MTPZ06
Default Trans Shift Detent Bolt
Anybody still doing the copper washer trick to work as a spacer on the stock detent bolt? I've done some searches on this, but most of the threads are pretty old...does this really help to reduce the notchy feel of the shifter, or is it all in changing the trans fluid to Amsoil, Red Line, RP, etc.?
Old May 23, 2009 | 09:57 AM
Chevy Guy's Avatar
Chevy Guy
The older threads are all still relevant.
Here is my opinion on the matter.
By shimming the detent you are bypassing/lessening the mechanical hold on the shift forks/gear sets. It makes the trans feel as if it is worn out and can actually allow a greater load on the shift forks by allowing a bit more slop.
With all that being said, some people absolutely love it. I personally did not, it made the trans feel sloppy and worn out.
Old May 23, 2009 | 11:21 AM
MTPZ06's Avatar
MTPZ06
Good to know. If that's the case, it's not for me either.
Old May 23, 2009 | 11:45 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I tried it and came to the same conclusion
I ended up putting mine back to the stock detent. I also like the 2008 ZO6 shifter which made the biggest improvement in overall performance.
Old May 23, 2009 | 12:41 PM
MTPZ06's Avatar
MTPZ06
Ordered mine about a week ago...looking forward to getting rid of the stock C5Z shifter. I think that upgrade in a addition to a fluid change will make a big difference in shift feel.
Old May 23, 2009 | 12:49 PM
Chevy Guy's Avatar
Chevy Guy
I'm another C6 shifter convert. Best upgrade you can make.
I got the same shifter from Gene Culley. Its an amazing shifter for the relatively low price. Its a world of difference.
Old May 23, 2009 | 10:24 PM
c5blkvetteguy's Avatar
c5blkvetteguy
I just did the washer mod. I used just one and it is better (not perfect) and does not feel loose. I think with two washers it would. I think it is worth the couple of bucks and less than ten minutes to install.
To Trans Shift Detent Bolt
