Water Pump Question
Old May 24, 2009 | 10:29 AM
Jamn's Avatar
Jamn
Default Water Pump Question
After only one year and about 8000 miles I have to replace my water pump again on my 01/C5. I can't remember what the torque specs are for the bolts that hold the water pump on. Can anyone help out with this?
Old May 24, 2009 | 10:33 AM
vettenuts's Avatar
vettenuts
First pass: 11 lb-ft
Second pass: 22 lb-ft
Old May 24, 2009 | 10:35 AM
donkelso's Avatar
donkelso
22 FT Lbs. They are supposed to be torqued in two steps, 11 FT-Lbs and final to 22.
Old May 24, 2009 | 11:23 AM
TEXHAWK0's Avatar
TEXHAWK0
Water pump should last longer than a year. I hope if you bought a new pump originally, they gave you a replacement for free.
Are you running the right mix of Dexcool and water? The antifreeze has additives in it to extend the pump seal life.
Old May 24, 2009 | 12:43 PM
Jamn's Avatar
Jamn
Yep. It shoulda lasted longer than a year. It was a new Bosch Pump. I noticed that cooling was always funky after installing it. Temp was somewhat erratic. I'm gonna try to get a replacement for free. Thanx for the torque specs
Old May 25, 2009 | 11:22 AM
Jamn's Avatar
Jamn
R & Red the water pump. I was guessing it was leaking from the shaft, but it looked like it was leaking from the rear plate that covers the impeller. Pep boys honored the warranty and replaced it for free. I also replaced the thermostat while I was at it. I noticed that the temp will still climb to about 235 degrees before the fans kick in and start to cool it down. I can't remember if it operated that way when it was new. Next project is to replace the oil pressure sending unit probably next weekend.
Old May 25, 2009 | 06:17 PM
416 Rigby's Avatar
416 Rigby
Default pulley/hub--
is this just a press fit on the pump shaft or?
To Water Pump Question
