ZO6 wheels
Old May 24, 2009 | 06:50 PM
jraft's Avatar
jraft
4th Gear
Default ZO6 wheels
I'm new to this forum and was wondering if a set of ZO6 wheels and tires stock size will fit directly on a c5 convertable with no spacers or other mods. also does the zo6 wheels have beveled lug holes or are they flat? 7/16 X 20 stud size I'm presuming.
thanks for the info,
John
Old May 24, 2009 | 06:55 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The Z06 wheels will fit on a coupe or convertible with the same lug nuts.
Old May 24, 2009 | 06:59 PM
jraft's Avatar
jraft
4th Gear
Default zo6 wheels
thanks for the quick reply, one other thing I have heard alot about is the "X" pipe when considering a new cat back system, what exactly does this x pipe do and does it need to be replaced?
John.
Old May 24, 2009 | 07:34 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
It allows for flow and pressure equalization in between the two exhaust banks. The stock system already has a cross over pipe that performs the same function. Some claim the x-pipe does a better job of it.
I believe GM incorporated an X-PIPE into their exhaust system design with either or both the LS3 & LS7 engines.
Old May 24, 2009 | 08:38 PM
jraft's Avatar
jraft
4th Gear
Thanks again
To ZO6 wheels
