Front and rear sway bar bushings are the common culprit and an easy fix.. There are 2 bushings on the front sway bar and 2 on the rear swaybar. Over time the rubber gets hard and you get the creaky,skeaky, groaning sounds.. You can easily loosen the bolts and liberally spread silicone grease to the inside of the bushings. Its an easy fix.. I took my 99 coupe to a service station and it took the guy about 10 minutes to lube them up.. I did them on my 02 z06 in about 20 minutes.. I can't remembeor the torque specs.. Maybe someone will chime in, as this is a very common problem. You can do a search if not.. There are aftermarket polyurethane bushings if you plan on putting new ones on.. These will never squeak or creak
Has anyone tried to just spray silicone lube on the sway bar bushing, let it sit awhile. My 99 vette just started doing that same noise over speed bumps as well. I may order new aftermarket polyurethane bushings for the front and rear to really resolve this problem. Thanks guys for the help.... what timing...
I tried lubing the bushings once and it made the minor noise into a major noise. I replaced those bushings and problem solved. I was putting a lot of miles on it so the bushings were lasting me only about 2 years.
My car is making the same noises like crazy. The dealer greesed it for me and that worked for a while but it's back. Do you know the part numbers of these bushing and where to get them? I'm interested in these after market ones previously quoted. Thanks.
I don't know where the idea that polyurethane bushing don't groan or creak came from, if anything they are much worse than stock. Lubing them and keeping them lubed is much more critical. They probably cured a noise problem because they were freshly lubed when installed. Anyway, whatever you have...lube it.
Gentlemen, I ordered a pair Front & Rear from Zip Corvette, best price around so far, $14.95 a pair.. If your C5 is a 97-09 and stock Coup (meaning not a Z06) or upgraded suspension. Front sway bar will be 23mm and rear will be 19mm then here are the part number from Zip Corvette.
Front 23mm SU-1103......$14.95
Rear 19mm SU-1105......$14.95
Add approx. $9.50 for UPS shippment, and your good to go..
There are new polyurethane bushings. Maximize your suspensions potential with quicker responses and predictable performance each time. These bushings are impregnated with graphite to prevent SQUEAKS. Black only. Sold in pairs. Fits 97-09 Corvette.
Awsome. I will look at these tomorrow to see if they have a Z06 version for me to purchase.
They do, I just installed them when I did a Z06 suspension conversion on my 98. Mine creaked and popped so I had to drop the sways and use more of the white grease that is supplied with the bushings. My recommendation is to use a ton of the grease and wear disposable gloves when spreading it on cause it is crazy sticky.
Chris
Hey again
I just went onto the ZIP site. I see the rear bushings (SU-1126) for the Z06 but I do not see any listed for the front. Do the front use common bushing with the non-Z06?
i just went onto the zip site. I see the rear bushings (su-1126) for the z06 but i do not see any listed for the front. Do the front use common bushing with the non-z06?
I covered this in the post on squeeking suspension. Check there.
I just searched (again) and checked a squeaking post that you responded in regarding greasing the bushings but I saw nothing regarding the part numbers.......I must be missing it.
I didn't list part #'s. What I did was cover how I plan to test the squeek/groan on my 99. Replace the adjustable shocks to confirm the problem. I have a replacement set ready to go when my health permits.
I see. Thanks for the update. I just want to get new bushings for now because they are cheap and when I bring it in to my buddy when we fix it, I will already have them on hand. I live in a smaller place so I can't just go out and pick them up if they are the problem.
