my boss, who owns a vast collection ( of Vettes), asked me about switching from 5-30 to 10-30 ....Mobil One. He was told the 10-30 lowered oil consumtion over the 5-30 ...what does the forum think..?
I use 5-30 in my maggied c5,, no issues. but, in my other cars I use 15-50 mobil one. ( hot rods,,,,older motors. )
lets hear your comments about the differences.
FWIW,,, I am considering changing to germnan castrol, as I used GTX for years and liked it very much....
please, this is for oil consumpion only,,,,,not brand pref....
High temperature viscosity is about the same for both, and near a 20 weight. I don't use Mobil-1 for that reason plus I don't like the way it coats the engine internals with a brown layer. After a lot of research I have been using the German Castrol 0W-30 and have checked the results with used oil analysis by Terry Dyson. The German Castrol results have been better than those with the Mobil-1 and I think I have made the right move. I have also had the motor open a couple of times and it is as clean as the day it was built. I would vote "neither" in this case.
The 10W30 high milage is a different formulation than the regular 10W30. It's SAE SL rated and it's viscosity at 100 deg C and HT/HS vis at 150 deg C are almost in the 40W range, read the product data sheets and MSDS on Exxon/Mobil's web page.
According to Mobil's product data, this blend is specific for engines with high oil consumption. In my case it did make a difference. I used to have to add at least 1/2 quart of oil after an autocross event. At last month's event I ran 14 runs and did not add any oil after the event.
good info,,,,nice to know. I did peep the MSDS,,,,
In my case, the cars I am dealing with are only driven a few hundred miles a year.
I will check it out but will likely stay with the GC.
