Valve seal question
Old Jun 5, 2009 | 09:23 AM
Tech's Avatar
Tech
@Cobra4B
Thanks for the link to ls1howto... however, I've been using that site for reference for years (including the first time I did valve springs). If a mistake was made, it was probably out of fatigue, rather than not knowing how to do it. I dipped the Patriot seals in oil... but decided to install the GM seals dry.
@Darkhalf
It's hard to say. I was exhausted (no pun intended) when I installed the Patriot seals the first time. The GM seals are longer and had more rubber surface on the inside (or whatever material it is). The Patriot seals that were still seated were very difficult to remove. However, every one of the intake seals on the passenger side was lose. There were also a few loose on the driver's side.
To recap... I installed the springs/seals. Had smoke. Tore it all down and re-seated the seals. I'm 100000% confident all of them were fully seated the 2nd time and 90% they were seated the first time. It wasn't until I went in for the 3rd time did I use GM seals. So far... I'm happy with the GM seals.
Old Jun 5, 2009 | 11:13 PM
Darkhalf's Avatar
Darkhalf
I've got new GM exhaust seals coming next week. Might be a couple weeks before I proceed with installing them, but we'll see.
Tech - what kind of cam did you install?
Old Jun 6, 2009 | 01:01 AM
Tech's Avatar
Tech
G5x1 228/232 .588/.574 112
I have 8 extra seals if you want them.
Old Jun 6, 2009 | 06:36 PM
Darkhalf's Avatar
Darkhalf
Cool! I got a G5X3 114, was just curious is all. Sure, I'll take em! PM me a price. Thanks!
