I've been having some pulley/belt noise that sounds like the bearings in one of the components is bad.
So I'm looking down at the serpentine belt, and the crank pulley is clearly not lined up with the other component pulleys. Whats more, the edge of the belt is actually riding off the edge of the crank pulley.
How can this be ? It's as if a washer or spacer is missing from end of the crank and allowing the pulley to ride inboard of the other component pulleys ?
Your crank pulley has 3 parts. The core, an elastomer band, and the outer shell which has the belt grooves.
Does your car have a chirping sound?
Your outer core is moving on the elastomer band seperating it from the core that is bolted to the crank.
You might as well buy an underdeive pulley to gain 9 rwhp, and since it's so much trouble (you have to pull the steering rack to get to the pulley) you might as well get a hotter camshaft.
Yeah, you could call it a chirping sound. I take it this is the source of my noise ?
How can the outer core move away from the inner core ? They are not bolted or attached in some fashion ?
The chirping is from the belt grooves not lining up anymore (compared to the belt)
With engine running, look/stare at the balancer, notice the groove have a slight wobble. The outer shell is clearance-fit over the elastomer... That's all holding it on. Over time the tolerances decide against your best wishes to seperate from the center.
ASP makes an okay underdrive pulley, Powerbond is a cheap (but good) choice too. All C5 pullies are the same, the problem was never addressed. n
I am simply amazed that they actually engineered a crank pulley in such a fashion. Thanks for your help guys, guess I'll be installing an underdrive pulley.
Hmmm, I'm having that same sound but mine goes away sometimes on it's own and sometimes it goes away with a little shot of silicon spray.
Comes back like to did recently after a nice wonderful rainfall like we've had the past ten days. Once I did notice it was noisy and the noise went away when I turned on the A/C. I didn't see anything unusual other than the belt didn't feel super tight. I figured it was just the belt needed replacing but now I'm gonna take a second look.
I answered your Pm, but I'll post here too incase this can help someone else.
If the balancer doesn't have a wobble, then the next common failure is the belt tensioner (Top of engine by passenger cylinder head)
Seems likely since the load of turning on the a/c can change the tension on the belt.
Tensioners aren't expensive, very easy to unbolt and replace, or you could get a solid tensioner from Katech/etc.
So since I'm having to remove the steering rack, it's worth going the extra mile and replacing the stock camshaft ?
well you are only a few bolts away to swap it out, so i would if you have the money to budget for cam/valve springs/pushrods/timing chain and maybe pump depending on mileage.
Yes. You can find used cams in the sale section for 50% of new retail cost, buy a new set of Comp 918 springs for $180, gasket for the front cover, get by with your stock pushrods or pop $99 for new ones. As mentioned maybe get a new oil pump and timing chain. Tune.
Ask yourself this question.... How long you really think you'll own that car?
If it's less than 3 years then you're wasting your money aside from repairs.
By the way, since this issue is apparently known as a common C5 failure, should this possibly have been a recall issue ?
No, because it usually doesn't happen until the car has quite a few miles on it. Mine went at about 100k miles. It's just one more part of the car that eventually wears out. It's not a design flaw.
Okay, but I've got to tell you, I'm 53 years old, and I have owned and driven many cars into the neighborhood of 200K or so, and I've yet to ever have an issue with a crank pulley wearing out.
How can you tell if the problem is with the belt or the belt tensioner just by looking at it? I mean, either one being faulty should look the same while the car is running.
