Nitto Drag Radials?
Old Feb 7, 2002 | 03:47 AM
redbob's Avatar
redbob
Default Nitto Drag Radials?
How much should you pay for Nitto 315x35x17 drag radials mounted on 17x11 Grand Sport wheels?
Old Feb 7, 2002 | 08:57 AM
Scott97's Avatar
Scott97
Default Re: Nitto Drag Radials? (redbob)
What condition are the rims and tires in?
Old Feb 7, 2002 | 09:47 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Rims alone are worth around 100-150 a piece. I would take what ever the price of drag radials and take off for wear. 1/2 used = 50% of original price. I would be more concerned about gettting the rims. New drag radials are cheap (at least in comparison to EMT's)
Old Feb 7, 2002 | 09:57 AM
Garceeya's Avatar
Garceeya
This is what I paid for brand new 17X11 grandsports and 315 nittos from AFS and discount tire direct. $823.50
I have some not so great quality pics if you would like them.
Old Feb 7, 2002 | 11:17 AM
Redvette_22's Avatar
Redvette_22
Being as these tires were designed for the Ford Lightning, they are supposed to be much taller then the C5 tires. If that is true and they are 28" or more, then you will loose the rpm equivalent to one full gear ratio. Another words if you have 3.42's you will see the drag strip rpm equal to approx. 3.15's, and so on. Is this what you want ? What is the purpose of you using the Nitto's for, street or strip or both ?
Old Feb 7, 2002 | 12:32 PM
Hissey's Avatar
Hissey
Default Re: Nitto Drag Radials? (Red98C5)
The 18 inch were made for the Ford Lightnings. I have these exact tires on my C5 now. Paid $500.00 for both. My car has a little less than 400RWHP and I have no slipping problems at the track. I must warn you that they are worthless when it rains. That much tire on the ground causes the back end to float when there is water on the ground. Just giving you a heads up.
To Nitto Drag Radials?
