From: Upper West Side, NY Very Downtown Houston, TX
Clutch Switch Retaining Clip
I had to take the clutch switch out in order to install my Tick master. When I took the switch off a small metal retaining clip popped off. Does anyone know how this clip goes bcak on?
The best I can tell the clip fits into the switch itself and locks the switch to the clutch bracket when you install the switch. There are two protruding square taps on the switch that engage the bracket. Once it is placed into the bracket the switch is slid down and the clip (aready on the switch) locks into a small hole in the center of the taps. Hope that helps a litlle.
