gears??
Old May 29, 2009 | 02:49 PM
INVISIBLEZ's Avatar
INVISIBLEZ
Default gears??
I'm about to put 3:90s in my 01 C5. I have an A4 and run 28X10 Hoosiers @ the track. I'm hoping it'll be a good improvement over my 3:15 gears that are in the car now. I run N20, and shift @ 7200.
Old May 29, 2009 | 03:18 PM
clif's Avatar
clif
St. Jude Donor '09-'10
be careful! I just had a brand new RPM 3.73 diff put in my car. In less than 400 miles, it died! RPM says they got a bad batch of ring and pinion gears from their supplier. Ask your supplier about this! I am going to have to have mine pulled out, and replaced with a 3.42, becasue RPM says they are recalling ALL 3.73s!
Old May 29, 2009 | 05:28 PM
chevylad's Avatar
chevylad
Did they recommend a break in period for the diff? Ususaly when you replace gears, you're supposed to heat cycle them.
Old May 29, 2009 | 07:05 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I installed RPM 3:42's about a year ago and the installer recommended 3 heat cycles and 400 miles or so.
Old May 29, 2009 | 08:06 PM
clif's Avatar
clif
Yes, the shop that installed them did two heat cycles per RPMs reccomendation. After that, I was told to take it easy for 500 miles. I never got over 3000 RPM, and never pushed it.
Old May 30, 2009 | 12:53 AM
futuretech's Avatar
futuretech
I went from 2.73 to 3.42 with an A4 and dropped .5 in my ET
To gears??
