Codes I keep getting
Old May 29, 2009 | 11:56 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Default Codes I keep getting
These are codes I keep getting on my Corvette:
P0440 H C
U1016-H... Loss of Communication w/PCM
U1064-H... Loss of Communication w/BCM
U1096-H... Loss of communication w/IPC
I know the three "U" codes keep showing "H" history, but why do they keep coming back?
And the P0440 shows "H" and "C" current.
Any help and advice would be appreciated.
Old May 30, 2009 | 09:48 AM
87SAM's Avatar
87SAM
From the service manual:
DIC Onboard Diagnostics Show DTCs U1016, U1064 and U1096 in History #PI00043 - (Jun 19, 2002)
Condition/Concern:
DTCs U1016, U1064 and U1096 may be present when scrolling through the onboard diagnostics via the instrument cluster Driver Information Center (DIC).
Recommendation/Instructions:
This is a normal software function as long as the DTCs have a history status upon ignition cycling. No repair attempts should be made.
On the P0440 the easy first step is to check that your gas cap is tight.
Old May 30, 2009 | 11:16 AM
renegad44's Avatar
renegad44
No wet/damp problems anywhere inside, I have the RedTop battery, so that's suppose to cut down on "acid" leaks, will check the terminals, make sure everything is tight and not leaking.
I haven't seen any performance problems, just after maybe 8-10 cyclings of the ignition, the codes re-appear.
I usually give the gas cap an extra 180* turn after the first click, maybe I've destroyed the gasket. I'll check that too.
Thanks guys.
To Codes I keep getting
