more power/performance from my 2004/ how??
Old May 30, 2009 | 07:24 PM
ssidekickbp's Avatar
ssidekickbp
Default more power/performance from my 2004/ how??
I have a 2004 c5 corvette and Have done some simple mods so far. I have a k & n intake, mass airflow sensor and a Borla stinger exhaust. I have been told to get a hypertech programmer to make the most of these? should I? Also, would anyone out there recommend that warrior manifold? or the 90mm throttle body instead? Please let me know. Is there anything else I can do to get more power from my car without supercharging it? Any answers would be helpful. Thanks
Old May 30, 2009 | 09:24 PM
SDLS1Rider's Avatar
SDLS1Rider
I think the first thing you should do is fill in your signature and give us a full description of your car.
A 90 mm throttlebody is too big for a stock manifold.
I would consider some long tube headers and a tune from from a reputable tuner.
Old May 31, 2009 | 07:44 AM
Gitusum's Avatar
Gitusum
I would consider some long tube headers and a tune from from a reputabe tuner.
and depending on what kind of "more power" you are looking to get there is also heads cam ud pulley if automatic a stall converter and basically the list can go on forever depending on how deep your wallet is and how much power you are looking to get. altho i found out there is never enough power and always want more!!!!
Old May 31, 2009 | 09:36 AM
vettenuts's Avatar
vettenuts
I agree with the above unless you are somewhere that a visual inspection is done for the emissions test. The MAF really doesn't buy much on a stock car. Headers and a tune will wake it up. The other option would be gears.
Old May 31, 2009 | 09:48 AM
ecoman's Avatar
ecoman
Get a Tune done ,had mine done yesterday by chuck cow and all i can say is wow what a change throttle response is amazing have to learn the car all over again do the tune you will not be dissapointed
Old May 31, 2009 | 11:56 AM
ssidekickbp
Thanks guys, what about this warrior manifold ? Is that any good?
Old May 31, 2009 | 12:12 PM
Gitusum's Avatar
Gitusum
i have never heard of that brand.
Old May 31, 2009 | 12:16 PM
ssidekickbp
it is on the mid america motorworks website.
Old May 31, 2009 | 12:17 PM
ssidekickbp
HTTP://content.mamotorworks.com/img300/fr8574.jpg
Warrior Manifold Made 32 more HP @ 4250 RPM and 31 FT-LB More Torque @ 4000 RPM Over The Factory LS6 Manifold!
One Piece Nylon 6 Composite Construction For Weight Savings & Increased Heat Dissipation
Accepts All OEM Sensors, Lines, and Fuel Componentry For An Easy Bolt-On Installation
Optimized Runner Design and Formula 1 Inspired Bellmouth Trumpets Significantly Increases Horsepower and Torque From 2,000 to 6,200 RPM
Open Plenum Chamber With No Support Poles To Disturb Airflow
The new Street Warrior C5 & C6 Corvette Intake Manifold was designed for one thing - power! This manifold delivers brutal low-end torque as well as killer horsepower throughout the useable RPM range. The popular LS intakes on the market move a lot of air to deliver top end horsepower at the sacrifice of low-end performance. You will feel the power gains right where it counts - the moment you hit the throttle!
Fits LS1, LS6, and LS2 Corvettes.
Product is expected to be available March 2009.
Old May 31, 2009 | 12:33 PM
ecoman's Avatar
ecoman
They been talking about that manifold for quite some time but never seems to be available do a search most people just gave up on it.
Old Jun 2, 2009 | 04:32 PM
chevylad's Avatar
chevylad
I ordered one a while back. Summit and Jegs both say early this month so we shall see if gets pushed back again.
To more power/performance from my 2004/ how??
