Codes B2264H and B2265H
Old May 31, 2009 | 11:19 AM
410gauge's Avatar
410gauge
4th Gear
Default Codes B2264H and B2265H
I am new to the forum and my 2002 Corvette convertible is displaying the following codes: B2264H and B2265H. Do I have a serious problem or is the automobile ok to drive until I can get to a dealer next week? Thank you.
Old May 31, 2009 | 12:32 PM
byronhunter's Avatar
byronhunter
DTC B2262-B2265
Circuit Description
The driver door module (DDM) and the passenger door module (PDM) receive mirror position signals from the mirror horizontal and vertical position sensors. These signals are used by the door modules for memory recall functions of the driver and passenger mirrors. The door modules command the mirror memory settings based upon the voltage level received back from the position sensors. Each door module provides a 5 volt supply, a signal and a ground circuit for each of the position sensors. The horizontal and vertical position sensors are variable resistors that the door modules monitor voltage levels across. When a memory setting is recalled, the door modules command the mirror motors in the appropriate directions until the stored position sensor voltage levels are achieved. The DDM and PDM monitor the signal circuits to determine if the voltage level is out of range. If the DDM or PDM detects a voltage level out of range for greater than 2 seconds, a DTC is set.
Conditions for Setting the DTC
The DDM or PDM detects a mirror position sensor signal voltage range under 0.1 volts or over 4.78 volts.
Condition must be present for greater than 2 seconds.
Action Taken When the DTC Sets
Stores a history DTC B2262, B2263, B2264 or B2265 in the DDM or PDM memory.
These DTCs can only be set as a history code even if the malfunction is current.
No driver warning message will be displayed for this DTC.
Conditions for Clearing the DTC
The DDM or PDM detects the correct mirror horizontal and vertical position sensor signal voltage range (0.1-4.78 volts) for longer than 2 seconds, and:
The DTC is cleared using the IPC clearing feature, or
The DTC is cleared using a scan tool.
Diagnostic Aids
An intermittent malfunction may be caused by an intermittent open or short to ground in a mirror signal circuit.
If the DTC does not reset after the code is cleared, then the problem may be intermittent. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Old May 31, 2009 | 12:39 PM
410gauge's Avatar
410gauge
4th Gear
Thank you byronhunter. What a wealth of information is present on this listserve. Thank you again.
Old Apr 20, 2023 | 10:04 AM
LouDogg's Avatar
LouDogg
Reviving an old thread.
I've been getting B2264H and after reading the above it has me thinking maybe it's the LED switch that I bought from Amazon. Everything works fine but the Drive side mirror likes to wonder. I reset the memory several times to no avail. Anyone else having this issue?
This switch doesn't have LED lamps. The LED's are build in the switch. The Amazon picture looks like you just replace the incandescent lamps with LED's.
Amazon Amazon
To Codes B2264H and B2265H
