Wipers park vertically..
Old May 31, 2009 | 02:08 PM
Juhatee's Avatar
Juhatee
Default Wipers park vertically..
Hello,
I haven't done any changes to my wiper mechanism, it worked couple of months ago but after long time not driving the car wipers are parking pointing straight upwards.
I removed the plastic cover in front of the windshield to see mechanism. Motor rotates CW normally when wipers are on. Wipers park in right place (or a bit higher than that) but right after that the motor turns 180 degrees CCW, so wipers park again but in wrong place.
What could cause this? I removed the wiper motor cover to see if there is something inside that's misplaced but everything seemed fixed.
Old Jun 3, 2009 | 05:34 AM
Juhatee's Avatar
Juhatee
Problem solved:
Mechanism which parks blades while rotating the motor CCW was missing one little spring. I made there a replacement spring and now all positions can be found again. Cheap fix but not very easy..
Old Jun 3, 2009 | 11:36 AM
timemender's Avatar
timemender
Good to hear that you found a fix. I wonder what happened to that spring. I've never had to get into the wiper motor or the wiper transmission on a C5.
Any photos?
Old Jun 4, 2009 | 03:42 AM
Juhatee's Avatar
Juhatee
Originally Posted by timemender
Any photos?
Only one:
Old Jun 15, 2009 | 06:37 PM
lexizpimpin's Avatar
lexizpimpin
Originally Posted by Juhatee
Only one:
any accual pictures of the sprrint and what does it connect to/??
Old Jun 16, 2009 | 03:30 AM
Juhatee's Avatar
Juhatee
I'm sorry but no. I made the spring using original spring holder. I made it by bending it so that it keeps the arm out.
Old Jun 16, 2009 | 06:01 PM
Sonnynme's Avatar
Sonnynme
Cruising
I'm having the same problems. When I turn them off they cycle once then "park" in the vertical position. Havn't had time to check it out as this was the first place I thought of to find help.
Old Jun 16, 2009 | 07:29 PM
TEXHAWK0's Avatar
TEXHAWK0
Have you read this??
http://forums.corvetteforum.com/c5-t...iper-arms.html
Old Jun 17, 2009 | 04:15 PM
Sonnynme's Avatar
Sonnynme
Cruising
Yep, I've spent the last two days researching this and I've torn into the area and found no evidence of water. I took the motor off and bench-tested and all seems fine except....when I turn the switch to off, the wipers cycle once and do a reverse about half way then stop. This leaves the wipers in the 1:00 position. I took the motor apart and then took the board off and saw nothing wrong but it still did the same thing. I'm think there is a switch within the housing that isn't positioned right but I couldnt see it when I took it apart....I'll look again tonight and take some pics....
Old Jun 18, 2009 | 03:23 AM
Juhatee's Avatar
Juhatee
Your symptom sounds exactly like mine.. Was there a spring attached to the arm (outside of motor, in the rotating part)?
Old Jun 18, 2009 | 12:16 PM
Sonnynme's Avatar
Sonnynme
Cruising
There is a spring that goes completely around the "cam" but thats the only one I see. I bought a new motor and installed it and it did the same thing so I'm pretty sure its not the motor. I took the board out and there are two contacts inside and I messed with them, just to see if they were burnt but they were fine. I reinstalled the old motor and now they park...but....now when I go to intermittent, instead of "parking" in the lowered position inbetween cycles, they stay at the one oclock position but at least when I turn them off, they go to the stowed and park position. This is really starting to **** me off, lol.
To Wipers park vertically..
