A/C Problem
Old Jun 3, 2009 | 09:21 PM
77BlueL82's Avatar
77BlueL82
Default A/C Problem
Help, it gets hot in a black car.
I can't make the temperature lower on the drivers side of the car. The heat stays on but as the car drives on it slowly gets lower a degree at a time. The passenger side is cold.
Old Jun 3, 2009 | 09:48 PM
geezel's Avatar
geezel
Many have found that a system low on freon will cause that problem. I had the same issue and had freon added today and now both sides blow cold. I'm not saying that's your problem, but it worked for me.
Old Jun 4, 2009 | 10:57 AM
jimcork1's Avatar
jimcork1
Check your freon using temp charts for your temps and see if you are low. My bet is low freon.
Old Jun 4, 2009 | 06:03 PM
77BlueL82's Avatar
77BlueL82
Thanks I'll give a try.
Old Jun 4, 2009 | 07:10 PM
spdracr39's Avatar
spdracr39
After checking the the freon try unhooking the battery for a few minutes and hooking it back up. I read a post the other day that said something about resetting the airbox door actuators this way. Probably be good idea to do a search to make sure there's not another step in the procedure.
To A/C Problem
