fuel filter
Old Jun 4, 2009 | 08:03 AM
drtyTshrt's Avatar
drtyTshrt
Default fuel filter
I used the search feature to no avail,can I get some help on changing my fuel filter Part#, location, tips and tricks.
Thanks in advance.
2003 stock
Old Jun 4, 2009 | 08:44 AM
mycorvette02's Avatar
mycorvette02
It is located on the left side frame rail above the muffler. There a 3 lines that require a release tool to seperate, a ground wire & 2 bolts. It is stuffed up on the frame rail. You can replace it using jack stands to get the car in the air. You will have a long reach though. If you have access to a lift it we be much easier.
Old Jun 4, 2009 | 11:58 AM
Bill 70Coupe's Avatar
Bill 70Coupe
If it is a late production 2003 it will have the upgraded fuel system on it and will not have a filter on it that you can change (filter is in the tank).
Bill
Old Jun 4, 2009 | 01:20 PM
drtyTshrt's Avatar
drtyTshrt
Bill
Thanks maybe this is my issue.
To fuel filter
