C5 battery draining. Please help!!!!
Old Feb 7, 2002 | 11:43 PM
C5VetteSC's Avatar
C5VetteSC
Default C5 battery draining. Please help!!!!
Hey guys. I read the discussions all the time, but this is my first post. I'm having battery problems with my C5 and I was hoping someone could help. The battery has a significant constant drain on it and neither I nor my local dealership can find the problem. We have taken out every fuse in both panels, but it still has a drain. We also disconnected the alternator, but this was not the problem either. Does anyone know of anything on a C5 that has direct access to the battery that does not run through the fuse panel. Any suggestions would be helpful.
Old Feb 8, 2002 | 04:23 PM
silversport's Avatar
silversport
Default Re: C5 battery draining. Please help!!!! (C5VetteSC)
This will at least get you to the top. Does the car sit for a while??? I noticed you have a '97...is it the original battery??? I would change it to an AGM just like GM did for 2001. Hope this helps or barring that, someone else sees this and adds their .02... :chevy :seeya
Old Feb 8, 2002 | 04:44 PM
Fast one's Avatar
Fast one
Default Re: C5 battery draining. Please help!!!! (silversport)
I'll check what the normal not running battery drain is and post it here Monday. My wintercar would go dead in a week with a good battery; the problem was a glove box light that didn't go off.
Old Feb 9, 2002 | 11:43 AM
C5VetteSC's Avatar
C5VetteSC
Found the problem. It was a bad switch in the driver lumbar seat. That little thing killed two brand new batteries in less than a week.
To C5 battery draining. Please help!!!!
